plasticarmyman
Android Expert
yeah worst case you'll have to unbrick and re-root.....no biggie...trust me...5 times in less than 24 hours
is there anyway we can unbrick and keep root?....i think that is the most annoying part of the process
then why the heck did you put up the link???? You should state whether it will brick you or not![]()
ok i downloaded the apk, installed the apk, pushed install recovery no options came up just said install was sucessful
clicked reboot recovery and i got a black screen with the home, menu, back buttons lit up....the buttons then went black with the black screen....pushed the volume down button and the reset android came up
so how will i know if it did install or not?
Soooo.. the Motion has cwm but just no kernels yet, right? I am confused...
Sent from my potato
after reboot computer not reading my phone so i can reroot....any one know why or can help me
I'm also confused, how much of CWM works????
Also kernels won't work until we get the bootloader unlocked, otherwise you are just flashing themes/themed ROMs/other stuff requiring CWM.
nothing works
in fact as far as cwm is concerned nothing has changed from 2 days ago :/
Is there any way to use the stock kernel signature on a custom one to confuse the bootloader
i wrote up a nice read on forging the signature on the files
what i mean is flashing anything is risky since the fstab (filesystem table) isnt for this device. imagine if you told windows to install and it went to the wrong hard drive and wiped out everything there? thats what you risk with a diff fstab
We should just push a modified boot image to the phone and see if it enters fastboot.
Mayhap we could compile CWM using our rec.img, board config, fstab, default.prop, etc. Determine what services need to be stopped on our device in order to allow mounting /system as writeable and reflecting this in the scripts. Following Dexter's methodology using the raw ramdisk, since we can't flash boot.img or rec.img to the proper partitions. Pack that shiznit up and test it. We should be able to use what we have as a roadmap. If I had another Motion I would test but I'm limited.
