PlayfulGod
Extreme Android User
as Shabby said thats dangerous with the wrong fstab in thereI think it will just brick...can someone use CWM to erase /system??? that will get you fastboot......if CWM works. I'm so confused.
most likely wont happen, need the key LG signed it with, and if its anything like what moto uses, it aint happening.So basically we have 3 options:
1) Forge the kernel signature
2) Get LG to unlock bootloader
3) Find a dev who can get the bootloader unlocked
I think 3 will happen first.
And unlike the LG Spectrum, no previous version available to pack up its unlocked bootchain and use.
getting to it in the apk isnt hard at all, it wont install/run afterwards.oh hell, ill try it if I can get into CWM from the 4X apk
you're sorta correct, the Boardconfig isnt on the device, it has to be written for it, granted Shabby and I have one, but compiling CWM isnt the issue, its repacking that apk or building a new to install it all and it all work correctly.Mayhap we could compile CWM using our rec.img, board config, fstab, default.prop, etc. Determine what services need to be stopped on our device in order to allow mounting /system as writeable and reflecting this in the scripts. Following Dexter's methodology using the raw ramdisk, since we can't flash boot.img or rec.img to the proper partitions. Pack that shiznit up and test it. We should be able to use what we have as a roadmap. If I had another Motion I would test but I'm limited.
And basically what happens is the bootstrap/2init loads the cwm files each time you boot to recovery
