from what I seen scanning the first page none of thats is for msm8960. I would double check b4 attempting anything and find the info for msm8960 instead of going by specs for msm8660.![]()
I think you scanned entirely too fast
What exactly happened when you used the tool to blow the qfuse and how are you sure its still locked?
Ok what about the 2nd bootloader project maybe this could work to get around our locked bootloader
Bootloader Project - OMAPpedia
What about editing the cab files to be pre rooted and modifing the bootloader take a look at what i found could this be the right track or is this way off?
http://forum.xda-developers.com/showthread.php?t=1891573
Even if it were pre-rooted, would not help unlock processor.
It would speed things up when we need to unbrick.
Hi,
Just wondering which device took the longest time to unlock bootloader.
And how long was it.
Does anyone know?
LG or all brands??
And most of the LG bootloaders were unlocked by fastboot OEM unlock.
Older LGs that were unlocked that got locked by an ICS update took, well idk, 3 months?? But they already had a way to unlock the bootloader by flashing the gingerbread bootloader. We don't have a gingerbread boot loader and LG phones that use msm8960 with gingerbread use a boot loader that's 3MBs. Our bootloader is 512kbs...
LG or all brands??
Just from reading the post you quoted,i would doubt itIs it possible to flash a gb bootloader and a different kernel that doesn't run security checks at the same time???
Its not likely you're going to find GB on a msm8960 device.Is it possible to flash a gb bootloader and a different kernel that doesn't run security checks at the same time???
So... do we have a way to trace security errors, to find what caused them? I believe I have blown the qfuse, using wallpaper, that contains our bootloader "lock", but... still security errors. Should there be any visual key that the qfuse actually blew? Ex: phone restart.
