Wipe Battery Stats
danielunde
I have just found out what and how to use Wipe Battery Stats, i bought an extended battery, when i got my battery in the mail i charged it for the first time the next day it was gone in about 12hrs, so that night i Wipe Battery Stats and it's been over 14hrs now and still have over 1/2 battery life left!:thumbup: p.s will let everyone know how long it go's....
k ur not supposed to wipe ur battery stats that doesn't make ur battery last longer when u get a new battery u gotta fully charge it then u gotta let it dye out then fully charge it that's the way u gotta do it for any new battery
that idea is no longer valid with lithium ion. they have no battery memory. you only decrease ur battery lifespan which is very long by doing that
Wasn't sure about that i'm new to a lot of this mrpnut still learning! Thanks man!
Well let me give you some advice since your "still learning".
It's always best to ask someone about something to get the info you need before you do anything to your phone. Last thing anyone wants is for you to brick your phone. Not that wiping battery stats will, im just giving an example.
So basically double check everything before you touch your phone. Make backups!!! And welcome to AF :shakehands:
If you read your manual, any manual for newer phones, it tells you to do that when you first open up the phone......................:call:
You are supposed to discharge your battery once a month or once every 30 charges. Your also NOT supposed to do deep discharge cycles daily when you charge. Your supposed to let it drain to a certain point, say 50%, and charge it to 100% and repeat this. It gives consistancy to the battery to better perform over a long period.
Pulled this off a site. After searching several site there were so many that went against the previous one. One would say one thing and the next would say another. But this is the one common thing among them all.
"Rather, to condition a new Li-ion battery, fully charge it; it should be allowed to charge for 7-8 hours on the first, initial charge. In other words, when you get your new cell phone - and it has a Li-ion battery - allow it to charge for 7-8 hours even if the cell phone claims to be fully charged. (It is preferable to use outlet charger vs car charger or USB charging via computer because of the voltage difference.) After that, there is no reconditioning necessary for Li-ion batteries since they don't suffer from the "memory effect". However, be sure to avoid fully draining/discharging the Li-ion battery as much as possible; every time a Li-ion battery is fully discharged, it loses battery power and life. (That doesn't mean your battery will die if it is ever fully discharged; it means it is best to avoid fully discharging when possible.) Try to recharge Li-ion batteries when they are at 15-25%. Similarly, avoid heat as much as possible and when (if) storing Li-ion batteries, store them not at full charge.
Update: The only time you should ever intentionally fully discharge a Li-ion battery is if your phone is not properly reading the battery. In other words, if you go from 100% -> 90% in ten minutes but go from 90% -> 80% in one hour with the same amount of usage, that means your phone is not reading the battery output evenly. If this is the case, then fully discharging your battery once and then recharging it can fix the issue of your phone not reading the battery properly. Take note, however, this full discharge/recharge won't increase your battery life -- it will only ensure your phone reads the battery properly.
People often confuse Li-ion and NiCad batteries and try to condition Li-ion batteries by charging/discharging them 4-6 times. Trying to condition a Li-ion battery like it is a NiCad battery (i.e. charging/discharging the Li-ion battery 4-6 times) hurts the Li-ion battery more than helps it. So, be sure to condition your new cell phone's battery, but be sure to condition it properly. Otherwise, you may be doing more harm than good. If you are not sure what type of battery you have, read the labels on the battery - they will always say whether the battery is Lithium-ion or Nickel-cadmium. Good luck and may we all have long lasting batteries".
Please cite your article (with a link) and use
tags.
Thank you.
Edit: I got a message asking me who I was referring to, and I was in a rush when posting that, so I apologize for not being specific. I was referring to Fuzzy's post, post #9 in this thread. Copying and then pasting a site's information without citing where you got it from is not something I would condone. I don't mean that you need to cite sources like you would for a term paper, but just saying "Hey, I found this article from this site <linky>" and then wrapping the quote in
tags gives proper credit.
