For those who want the official wireless charging kit..HERE IT IS..I received mine 5 days ago. I ordered the black cover and I use the Samsung wireless charging pad from amazon, the one for the S4, it works excellent with the S5.
I ordered mine from ebay, as well it is an authorized Samsung seller, this is the genuine wireless cover for the S5.
Samsung EP WG900IBEGWW Wireless Charging Pad Charging Cover Kit for Galaxy S5 | eBay![]()
I have had no problems with this charger and cover, I just put it on the pad and it says "your device is now charging wirelessly" when it is fully charged it jusr quits charging even if I leave it on the pad. I would recommend this for anyone who wants the wireless charger..this is the link for the charging pad
http://www.amazon.com/gp/product/B00F358AVI/ref=oh_details_o00_s00_i00?ie=UTF8&psc=1
Weird, but that worked. The screen still turns off after a minute but it charges to full now. Genius. Well I'll have a base in the kitchen and in the bedroom too.In Developer options, which I have turned ON, I have a check mark for "Stay awake" while charging.
That to me means the Lockscreen will stay lit up, but on my VZW S5 the lockscreen goes to sleep just like always and it continues to keep charging until it reaches 100%.
I am "assuming" that the S5's internal charge regulator will cut back the charging rate, or in the case of "my setup" using Battery Doctor, BD controls the reduction in charging current.
I can only say that the el cheapo wireless charger has always worked for me "so far". I have had it installed about 2 weeks and only used it 4-5 times as I get 3 to 5 days use between charges depending on how much of the "outside world, ie DATA, WIFI" I need to use.
I make my normal telephone calls needed for job, family and friends plus sending text messages. neither of those features require a DATA connection.
I never turn Sync ON unless I want to update email... but that I don't mess with unless I am on the desktop PC at home.
Black Qi Standard Wireless Charger Charging Pad Receiver for Samsung Galaxy S5 | eBay
Is there more than one official kit? The one just above this post uses a 1 amp charger and the small pad. The larger pad that Samsung offers is a 2 amp charger and it seems silly to charge at a slower rate than the Samsung S5 USB charger which is also 2 amp and comes with the phone.
The Generic Wireless Charging Receiver Pads that I have seen all seem to have an output of 1 amp or less. Has anyone seen one that is capable of 2 amp charging?
I'd like to avoid the official Samsung wireless back cover as I have a couple S5 cases that, apparently, won't fit the new back.
I have a Ringke SLIM which I like a lot and an Incipio Feather which I'm not so thrilled with because the power switch seems to love to turn the phone on and off in my pocket at random. I hope the factory back will fit in either of them.I use the larger charger from amazon..not the small one with the kit. I just ordered that one because I wanted the Samsung wireless back my spigen case fits fine over the wireless back. and yes it charges with a case cover on the phone..
but this sounds like the combination I'm looking for IF my Spigen case will fit. I have the Spigen Ultra Hybrid case.Isnt this the better way to go for wireless charging?
Amazon.com: S5 SlimPWRcard - 0.5mm Qi Receiver for Samsung Galaxy S5 SV: Cell Phones & Accessories
