I've gone through these and other forums at length and I can't seem to locate a solution.
Running:
HTC EVO 4G
CM 7.1.0
2.6.37.6-cynanogenmod-01509.....#1 (kernel)
I uninstalled the wireless tether app, rebooted phone and laptop (chromebook) and attempted to use the wireless tether app included. It shows no error upon launch (was erroring when wireless tether app was installed). I attempt to connect both via secure (WPA2) or open and my chromebook will not locate the hot spot.
I previously used CM6 with the app and worked perfectly. And advice or links would be greatly appreciated.
TIA,
AarJohn
Running:
HTC EVO 4G
CM 7.1.0
TIA,
AarJohn
