I completely get why some folks would like a big battery, but I ended up going back to stock size. Got tired of the extra thick size of the device with the Hyperion and like using the clam shell case with built-in stand. I simply carry a charged 2100 mah battery in my wallet as a back-up.
The 6300 would be way too big since the 4000 mah got old for me. Three times the thickness of stock would be mega-chunga. That might be classed as a weapon in some territories![]()
Should I let the battery die for each of the 5-6 cycles ?
I would like to know this myself.
Yeah, I was about to ask the same question.
Same question here....
In a word:NO!
Run it down to about 5%
As a rule,it's not good to totally discharge a LI-ION battery.
.Another question. How long is the average charging time . I know the first time was 12 hours but should it be that always or does it require more time to charge ?
For the ones who have this, how is the thickness compared to the Otter Box defender case? after today, I really need to buy this battery.
About the same
in weight yes but the actual size isnt really noticeableReally? I figured it'll be a bit bigger than the OB.
Hi, I'm planning to buy this today, but first of all , does this work for Metropcs Samsung Galaxy S3?
^^This
That's the only complaint I have about this battery
I've seen some modify an otterbox defender to work like that, but I rather not risk messing up a $45 case just for that![]()
You can get Defender cases for $30 these days. I saw bestbuy.com selling them for $30 back in late June and I got the local store to match. IIRC, Amazon sells them for around $30 too. I did return it though as I didn't like the feel of the built in screen protector and removing it seemed to defeat the purpose for me.
Got this the other day but it doesnt seem to be much better than stock, im currently down to about 20 percent with 2hrs 30 screen time.
I assume it will get better once the 5 or 6 cycles have taken place?
