Yes you are correct sir
Thanks for that mate, i was worried i spent twenty quid to just make it bigger and heavier.
Got this the other day but it doesnt seem to be much better than stock, im currently down to about 20 percent with 2hrs 30 screen time.
I assume it will get better once the 5 or 6 cycles have taken place?
Keep an eye on that. 2.5 hours seems rather low to me (lower than stock) even before cycling it several times.
With my 4500 mAh Gorilla Gadgets, it was pretty obvious from day-1 that I had roughly double the capacity. By the second discharge cycle, it was even more clear to me.
Will do, sadly this week i have a longer commute than normal so im perhaps bashing it a little with the 3g etc.
1 hr 26 and now at 34 percent after taking it down to 4pc last night.
not sure about this now. may send them a mail.
thanks for the advice peeps
Keep the screen at 100% brightness. Then use it like you normally would. When you're at 50% tell me what percent your screen used. Also, if you're not at exactly 50% tell me exactly where you are. I'll dig up a screenshot of what I'm looking for in a bit.
A lot of Amazon reviews complain that ZeroLemon 7000mAh interferes with 3G/4G signal and GPS reception, and that the battery life degrades quickly after the first couple weeks of use. Can anyone confirm or deny it?
Why don't you send it back for a refund or exchange? It has a 180-day (6-month) full warranty.I've had my zl for two months.. For the first few weeks it used to last me two days... Now.. It does a day..
I can't wait.
I've finally seen someone show a comparison between the Zero Lemon and otter box case and there isn't much of a difference. I might have to mod the ZL case so it can fit in my belt clip lol. I'm not a fan of putting my phone in my pocket or holding it while I walk.
Oh wow its actually went up in price.
I got lucky and paid $25 for mine some odd 3 months ago or so lol
I wish I knew about this battery back then. I've never been so hyped for a battery in my life, lol. I can't wait for it to get here ^_^.
You won't be disappointed I can tell you that.
I can't see me getting rid of mine until I upgrade.
When I bought Anker 4400mAh extended battery in January, the ZeroLemon was not available yet.
My Anker 4400 has started developing problems since June, (i.e., it's losing charge faster and faster, and now it lasts less than five hours of normal use; it's getting overheated and hot during use; and its physical size has gotten fatter and fatter that it can no longer fit into the extended back cover.)
Fortunately the Anker battery has an eighteen-month warranty. I emailed Anker and gotten an RMA. So I am using this opportunity to "upgrade" to a ZeroLemon 7000. I will send back the Anker to get a full refund as soon as I receive the ZeroLemon I ordered from Amazon.
I just do not like ZeroLemon's six-month warranty policy. I've used a number of extended batteries. They often start to show problems at around six months of use. The six-month warranty is really stingy compared to Anker's eighteen-month.
The only way I will is if it's a defective battery. If not then I'll be doing the same until the Note 3 is released, can you imagine a ZL battery for that? lol.
