Installing right now. Its always a good sign when your phone goes from "M" to boot screen quickly. It's those lingering "m" screens that freak you out!
Everything works except for my corporate contacts. They are not syncing up.
Does this have the blur txt messaging app?
So has anyone installed this over the 2.2 OTA (is it even possible/recommended?) and if so how would one go back to the 2.2 OTA should they want to later on? Would it be as simple as doing a restore through clockworkmod? or using the /system sbf?
@Prevlin-I used this to put a deodexed stock back up on my phone
I'm pretty sure that messing around with ROMs with the 2.2 OTA bootloader is ok, since if all hell breaks loose, the worst you can do is hose your /system partition, which is exactly what the SBF restores.
It'd be very hard to mess up the kernel, radio, or bootloader![]()
Still... does anyone know if it i his first post.s necessary to wipe data?
If its based on the leak, I'll pass, since the OTA gives us MUCH better reception here. We live in the mountains, and in some places where Iphones are struggling with 1 bar, we have 3 with OTA.
Anyone know if it is necessary to wipe data? I hate adding all my contacts back everytime i try and be rom out.
can sum1 explain how to install roms and themes over eachother? im confused. im running the deodexed black glass 1 right now and am loving it but also want to try new stuff as well.
