Prinny
Resident Linux Nutcase
I would have answered sooner...but work is a cruel mistress. Confirmed as working. I can't believe I didn't look in the build.prop...I over analyzed it as always. Thank you krowley!
I got a problem here, I'm using gangnamstyle ROM (sprint version) I did the MMS fix I can receive and send MMS to other people but for some reason I cannot download or see this particular person's media messages is weird..is any one else having this problem..by the way he has sprint network idk if that could be the problem?? Just saying... this a screenshot of how his media messages show up on my phone.
- For those that care, I have been working on bringing back the themes and making a new one but time and life have not been my friends
Someone should let mazda know that change fixed MMS on SlimBean. I'm sure he would appreciate it and the build.prop changes with each release so it would be a hassle to maintain that fix.I would have answered sooner...but work is a cruel mistress. Confirmed as working. I can't believe I didn't look in the build.prop...I over analyzed it as always. Thank you krowley!
ramjet73
Yes, I understood that, but what I meant is that the build.prop file changes with each release for at least the version and build date and possibly other values if mazda fixes something. Since you are replacing rather than editing the build.prop file in the fix zip for SlimBean it can only be used for one version, and someone would have to update the zip file with the new build.prop every time a new build is released.The build.prop was the only change that I made from the other CM10/AOKP MMS flashable zip.
Hopefully mazda will incorporate the build.prop changes into the next version so the fix won't be necessary for Sprint users and the build.prop file can be removed from the VM version. Otherwise, the changes could be done as an edit in a script rather than a total replacement of that file.
Edit: There's a post in the SlimBean thread on XDA where neogenx says flashing the MMS fix zip reverted his dpi density back to the default. That makes sense because it and other system parameters are stored there, which is why concatenating new parameters via an edit script is recommended over completely replacing build.prop.
ramjet73
I have a script that edits the build.prop file in the updater-script that can be modified for those parameters if needed, but hopefully mazda will incorporate them in the next release so that's not necessary.You make some very valid points that I did not think of. That is why I put the only thing I changed in the post. I have no idea about how to make a script to do that, that is way out of my league. Hopefully he will incorporate the fix so we can just use the same flash for all AOSP roms except Evervolv 4.2.
Am I missing something? I flashed the slim bean zip but the mms app still doesn't send. Can send with mysms though.
Before u flash erase your mms app in system then after flash wipe dalvik /cache.. Mms is working great for me.. Note= sending and receiving mms seems to take a bit longer on this rom.. Give it time..
HeyI couldn't get this to work on miui. Even changed build prop tovm
The miui zip is for the jelly bean version, not ICS
I can confirm this works with Go SMS Pro if you clear out the custom settings for MMS in the app. Just worked perfectly.
I've tried it. I had flashed it and downloaded go SMS pro and didn't set custom settings. Didn't work for me. Can you explain a little more?
Having an issue with receiving on 3.5.2 AOKP. I have a message thread going, and when they send an MMS it shows up as a new message thread that appears to be a forwarded message from my own number. I've read through the thread and couldn't figure out if anybody else had this issue.
I'm using the latest Stock MMS zip from the OP (CM10 +cache). Tried just about every install method, and just looking for some advice before I do a complete reinstall of aokp to start from scratch.
I am actually receiving the picture, but just in a strange way. Have a screencap link below.
Screenshot of what I'm seeing
