davidmargolin
Android Expert
Does this file have to be renamed to mms.apk?
nope...
dont have to do anything except for
move to system/app
then set permissions
then reboot (dont try to install)
profit
I would like to try out the mms fix but i'm having a problem moving the old mms
apk.The file can not be move I get this warning saying mms.apk cannot be moved because the file system is read-only,what do I need to do???
Thanks for the quick reply I am using Rom Winmax 11/21/12 JB 4.1.2 ParanoidAndroid 2.99
What i did was long press the Mms apk then press move when the window open,
is that the way to do it???
Will not let me move file not sure what to do next any ideals.
Move the mms apk that came in the rom and replaced it with the one you have
now how do i reset the permissions.
All this is new to me,thank you for taking the time to help me.Now how do you change the permission what are the steps where do you start.
which version do you want??? ill make a flashable zip... i never made a flashable zip in the past but ill try to make one...
Would this work on CM10? I tried installing it but it said the app could not be installed. Everything seems to work except MMS. I'm also on the Sprint Radios so I don't know if this is the real cause for MMS not working but im on CDMA: .97.10.0808 (was on .0530 and no MMS either).
actually I saw a lot of "r/w" issues posted and I was like....it says to change that...but then you know, not doing much better than them lol. Anyway, I did manage to copy in "Stockthemev1.1rev2.apk" but no love unfortunately ): I'm using this ROM specifically: http://forum.xda-developers.com/showthread.php?t=1873926
Edit: Looks like the post above answered my question
