pworcester
Member
Update from ZVB to ZVC is being pushed out. It disables Universal Androot.
When you try to root it fails with " No Fu goo"
that worked. Thanks!
FYI, now that you're rooted with a different ROM, OTA updates like this won't be pushed.
Yea you have to manual push it by finding the zip..
Which you wouldn't want to...unless it's 2.2![]()
Well Correct me If I am wrong... But isnt it good to take the update and then Put your Nandroid back up on?
This is what I did when ZVB came out.
SO I got the benifits of having the ZVB Firmware with NONE of the Bloatware.
So I am running Velocity .3 with SW Version VS740ZVB
Wouldnt it Behoove you to do the same thing with ZVC?
Not really, I see no benefits from updating to ZVC unless there is a new radio, in which case I'll flash that separately when a .zip is released.
I guess the next question... Will it Hurt to update? I was under the Impression it will not Hurt.
If you remove the bloatware that comes with it then no it won't hurt. Then again, it most likely won't help enough for it to be worth your time.
Ha thanks swc2001
