[Free Game] OLO - One Level Only
- By olbriar
- Apps & Games
- 3 Replies
This is an English speaking site. You should consider translating your posts to reach the majority of our members.
Note: I referred more links I tried all solutions even though I didn't get solution.Unable to resolve dependency for ':app@debug/compileClasspath': Could not resolve com.android.support:design-v7:28.0.0 Open File Show Details
Unable to resolve dependency for ':app@debugAndroidTest/compileClasspath': Could not resolve com.android.support:design-v7:28.0.0. Open File Show Details
Unable to resolve dependency for ':app@debugUnitTest/compileClasspath': Could not resolve com.android.support:design-v7:28.0.0. Open File Show Details
Unable to resolve dependency for ':app@release/compileClasspath': Could not resolve com.android.support:design-v7:28.0.0. Open File Show Details
Unable to resolve dependency for ':app@releaseUnitTest/compileClasspath': Could not resolve com.android.support:design-v7:28.0.0. Open File Show Details
I am also confused. If the contacts had permanently disappeared, I would say either I accidentally deleted them or I am hacked. But for the contacts to "disappear" and then "reappear" looks to me more like Google's back end has a reliability issue.I'm confused, I have never lost a contact from Google Contacts. many have been on for years without being used. I currently have a Pixel 7
man first login to system version ( and click the MCU number several times then put the password ( you have to double check what is the password ) from that you have to enable both USB debugging and developer mode). then from the screen setting you have to go to build number and activate the developer mode ( by clicking the build number several time 7-10 times) then go to USB configuration and change the USB to transfer file mode. then you are ready to add whatever app you want. i can help on that if you need free of cost. at any time
Hello how are you?man first login to system version ( and click the MCU number several times then put the password ( you have to double check what is the password ) from that you have to enable both USB debugging and developer mode). then from the screen setting you have to go to build number and activate the developer mode ( by clicking the build number several time 7-10 times) then go to USB configuration and change the USB to transfer file mode. then you are ready to add whatever app you want. i can help on that if you need free of cost. at any time
Ah awesome thanks, I will check it out now!Textra is a highly customizable messaging app that offers various features, including an auto-reply feature. You can set up personalized auto-reply messages for specific contacts or general replies for all incoming messages.
Is this app useful or not?
Don't be stupid, I can play AC/DC from my music collection, so it must charge with a bit of AC too or it wouldn't sound right.I THINK ITS DC
Alright. I've heard that from a couple forum posts and from some other users as well, but those cases usually deal with both a smart watch and an audio device. I'm not sure how that would translate to an audio receiver and a detector that, as far as i know, doesn't take in or output audio via bluetooth.
Nuts, I mistakenly wasted your time on Wondershare. My apologies
Reading further this worked with the older Samsung Kies backups but Samsung continues to upgrade its encryption protocols in its newer SmartSwtich backups so this no longer applies.
This link is an interesting article on the matter, decrypting a SmartSwitch backup:
But apparently the report is based on using the SmartSwitch utility, which in this particular instance is the heart your problem -- getting that elusive phone call log to successfully import into the Phone app on your new phone. I'm out of other suggestions.![]()
How to decrypt PIN-Based encrypted backup data of Samsung smartphones
Smartphones, which are a necessity for modern people, have become important to forensic investigators, as they have a lot of user information which ca…www.sciencedirect.com
