Finding someone to root Droid Maxx 2 for a fee
1. carrier unlock and bootloader unlock are two different things. the "device is locked, Status 0" means that you have a locked bootloader. it will need to be unlocked first in order to root. so yes this is why kingoroot will not work.1. If I see "Fastboot (Secure), Device is LOCKED, Status Code: 0", does that mean that even the carrier cannot unlock the phone?
2. If the carrier can do it, can I just waltz into the carrier's local store and ask them to unlock it?
3. Will unlocking the phone delete all the data? (An online remote rooting service is telling me it's not possible without a factory reset.)
4. Instead of rooting, is there a way to backup a phone including all system and hidden files without rooting? Then examine the files from their backed up location?
5. Should I have started a new post with this comment?
2.a carrier will not unlock a bootloader for you. they may allow it, if they so choose. like moto can provide you with unlock codes to unlock the bootloader save for verizon's moto's
3. yes unlocking the bootloader will delete data. not sure if kingo Root will though.
4.nope
5.no you are good. this is your thread so that's up to you.
edit: sorry i did not respond sooner. had a super busy week.
