The phones with the best / most accurate compass sensor
I came here from the future (2023) to tell you all that what Android calls a "compass" is really only a simulator these days. Unless you pay for a top of the line android phone - your "compass" is software, using WiFi signals and other data to simulate your location. The hardware version of a "compass" is called a magnetometer and it took me two hours of searching to figure out that my Galaxy A13 does not have one. I am disappointed because I can't contribute to CrowdMag when I only have a "simulator" on my phone. It also points to a larger looming problem with smartphones getting too smart for basic efficiency and people believing they can do things they, in fact, cannot.
Horseshoes... Yes Horseshoes
Horseshoes has the same basic motion as tossing a bag of beans / corn or whatever they stuff the bags with. I've only tossed a corn bag once. It was set up outside an upscale burger establishment. The party I was with each took a turn for fun before entering the eatery. I lucked my toss directly into the hole. I know there is a lot more to the game than making that shot. Everyone took another shot after eating except me. Why prove my first shot was pure luck. :)
Back when my son was still playing baseball, a common time killer between games was to play washers. The game reminds me of cornhole and horseshoes in that you toss an object a given distance at a target. Cheap entertainment, much like horseshoes, has had a following around my area all of my life.
Beautiful Widget time not updating?
Also, as posted earlier earlier, both Task Killers and Home Replacement Apps can cause the time to not update.
For the Task Killer, put BW in the EXCLUDE list.
I have had issues in the past with the BW time not updating when using the Sweeter Home 2 home replacement app, but I have not had any issues as of late with it.
I know this is a very old post, however I've been using the beautiful widget clock app ever since it came out and it was wonderful. After the new update everything works except the display of the clock. I'm not using either of the two apps that you mentioned above. Do you have any suggestions. I've also written to the developer in the app store with no reply
Which IDE?
Do not be sad, there is several other IDEs which you can use for Android Development e.g. CodeGearRAD studio - Delphi(pascal) or BuilderC++, Qt/C++ for Android, Lazarus for Android in pascal, MS VS 2022 VisualBasic Xamarin, MS VS 2022 C# MAUI Xamarin for Android, TizenDevelopmentStudio C/C++ for mobile phones + tablets + TV ... and many others. So, you can choose anything...
LG tablet refuses to update
Hello, I was given LG G Pad F 8.0 as a gift to me. LG stopped giving it updates on Aug. 31, 2018, with version V49520m, and it is discontinued, that is OK. I would like to get to the final version, and I see no reason why I can't do that. I am currently on version April 26, 2016 V49520g. When I go to Settings > About Tablet > Software Update, it says it is on the latest version, but that is incorrect, it is on version V49520g, when V49520m is the latest version. I have been on over 100 mobile devices, and I have never seen a device block itself from updating like this. I have already factory reset it twice, there are no custom settings, personal files, extra apps, or SIM card in the device. How can I proceed? Thank you everyone.
AT&T doesn't allow their Android devices to OTA update over wifi unless an active AT&T SIM is inserted. Don't ask me why - I have no idea.
If any friends or family members have AT&T, you can pop in one of their SIMs to pull the update
Samsung A51 MetroPCS painfully slow after forced update yesterday.
I doubt messing with the cable will fix anything. It's more likely the female connector has seen stress or wear causing it to to make a loose connection. If a different or new cable acts the same, perhaps a fix it store can replace the c port connector for you.
I would try the compressed air. Sometimes lint collects in the port and keeps the connection from being sound.
Filter
