What apps are these icons from?
If it's anything like my experience with Facebook in 2011, You can clear them all you want, but you'll get dozens more minutes later. I had like 400+ friend requests, I'd wager many of them bot accounts, back then. Since their whole 2FA crap began, I can no longer log in to see what the current state is. It literally refuses to work, won't let me reset. Guess that's a good thing!
It had separate notification icons for likes, comments to posts, etc. It was a mess. The last login I had was on my Note 10.1 tablet in 2019, November, and with an old, outdated version. The News Feed was broken, but I could still access one page that made for great reading. Never participated much. It was just as awful though with the notifications and I had to disable all of 'em. Eventually they enforced a weird form of 2FA that doesn't work (at least, it alienated the heck outta me) and that app logged out and ceased to login again, and I can't login with a laptop either. I think it went like, to reset my password (since to them it was not secure enough--nothing like making one so convoluted that it requires putting it on a post-it note on the monitor--real secure bruh!) I had to have it send a code to my phone number, but that number no longer exists (was last on my ZTE Merit in 2011!) so I'm SOL.
Facebook did two things for me:
1. Learned what FarmVille was; got me into mobile gaming at the time
2. Most important, it's how me and my girlfriend met.
Today, it no longer has a purpose in my life. FarmVille is dead, so are many mobile games I actually liked (I got APKs of a few that still work, such as the original Angry Birds and Plants vs. Zombies) and the relationship with my girl is just as strong as ever so I'm not looking for another.
Txt files saved on phone?
Where on the phone the files are could be important, but "My Files" isn't a location, it's an app. It should be able to tell you where the files are though. I don't use it because there are better file managers (true of most built-in apps), but I guess if you find one of the files, long press to select it, then look for the little 3 dot menu button one of the options will be "details" or something like that. That should tell you the "path", i.e. where in the filesystem the file is.
".txt" just means it's a plain text file, tells us nothing about the content. The "log" part in the first on suggests it's a log file from some service or whatever. Probably harmless to remove, but unless it's large it's also of little importance. One whose name is just a date can be anything, so where on the phone it is will be the only way to judge whether it is of any importance, unless you just open it up: if you click on it that will tell you whether you have any app installed that thinks it can read plain text files.
Fast Notepad files location on Chromebook
Hi.
I found a thread about the location of the Fast Notepad files, but it didn't help me at all. I found some app files under Play files/android/data, and according to the thread I should find a folder named "com.taxaly.noteme.v2", but it's not there - I can identify the apps that all the folders belong to and fast notepad isn't one of them.
I have several notes on it so it has to be somewhere right? I have a Chromebook CB311-9H-C5KP (N17Q8). Where else could I look for them? I need to reset my chromebook to factory settings as it's being glitchy, so I would greatly appreciate any help I can get. I'm attaching a sreenshot of the folder although I don't see how it'll help - the "Color.Note" you see is for another notepad app called Color Note".
Thanks in advance!
Help What is wrong with connections
WiFi calling works just fine on my Galaxy s21. My daughter had weak signal in her last place and used it all the time (s8 and s21). So it definitely does work reliably. However as we're in Britain we are not using the same cellular or broadband provider as the OP, and our phones won't have Verizon-modified firmware. So if one of those is a factor then I've no idea.
Deleted wifi connection
It's not an option to access the router's setup for me. My phone is getting ip from router like everybody else. There is a mac address defined as a privallage user, bu luck, at first connection my phone took that mac adress, I was using internet without limitations, I deleted the connection from my phone and reconnected. Now I have a different mac adress with no privillage. I want to find out my old random mac address, if I can find it, I will change my phone's mac address and gain unkimited internet again. Is there a file in the android system that old connections or mac addresses have been stored?
So when you have random MAC addressing enabled in your phone, it's the Android operating system that determines the random addresses. You do not have any way to set it up to what you specify. So hypothetically, even if you were able to magically find out just which MAC address your phone was showing at that time whenever someone set up your phone to use this router's WiFi access, that particular MAC address is irrelevant. You are not going to be able to duplicate it anyway.
It's still a matter where you need to either A) disable random MAC addressing in your phone and have whoever is in charge of this router's maintenance and upkeep to reassign your phone a new WiFi access now based on your phone's actual MAC address or B) leave random MAC addressing enabled on your phone and convince the router's manager that they should allow your phone to use DHCP instead of assigned IP addressing so it makes no difference which MAC address your phone might be emitting.
You can keep trying to mess with your phone but it's how the router is configured that's the source of your problem.
Recover Data from Several Android Phones with broken screens
I was in Spain doing an extended hike over 2 months. During that time I m managed to break 4 phones. They appear to be damaged primarily on the display as they all seem to work to some degree e.g. alarms come on when they are powered. Unfotrtunately none of them are set to Android remote control as I bought them while hiking and did not have the time to set this up. They have never been on my home network or had a sim card from my country. I was hoping to use a USB hub with HDMI to access them using an external mouse, keyboard and monitor, but I tried this on one and nothing much happened. What can I do? The devices include a Huawei P20 Pro, and Redmi Note 10C, a cheap Realme phone. All were Android. Thanks
With the Huawei device, you can use a MateDock with it. Which is a Huawei hub with HDMI, and can use a keyboard and/or a mouse with it. However the MateDock is proprietary to Huawei and Honor phone only, and won't work with the Xiaomi and Realme devices.
Help Go to date calendar feature
I think they have ads precisely because you are using the free versions. I have the paid versions of all 3, and hence no ads; I work on the principle that it takes time and effort to write and maintain apps (I know because I do software development as part of my job), so I've no problem with paying a small sum to use them - and compared to PC software it is indeed only a small sum.
Fair enough, must admit I haven't looked at what they cost so that may be the correct thing for me to do ;)
Transparent notifications lockscreen and quick settings panel
Hi,
I have Android 11 Stable on my OnePlus 7 Pro. I don't have the rooted phone, nor do I want to. I would like to know if it is possible to have the notifications on the lock screen in semi-transparent cards. And equally apply it to the quick settings panel. This option that exists, for example, in Samsung devices, does not exist in OnePlus.
With the dark/light mode, logically, all I get is a dark or white background.
I don't know if it would be possible with Andromeda and Substratum. And if it were possible, with what theme would it be achieved?
Or in some other way.
Filter
