Can't flash custom rom
- Smartphones
- 4 Replies
I think it must be unofficial because the lineageos site shows this device as discontinued. So with that in mind I'll abandon this.
Hi all,
I have a stock S9 on T-Mobile and use Google Messages and/or Samsung Messages (the built-in app.)
I travel internationally and recently started receiving "gentle" reminders from T-Mobile that "roaming benefits are not intended for extended use abroad." You know, "Sprint + T-Mobile, better together", blah blah blah.
I am usually on wifi so I disabled roaming expecting hardly any consequences. And had no issues except I discovered that I am unable to download MMS messages (photos or texts in groups) UNLESS I enable roaming again.
This is happening with both Google Messages and Samsung Messages apps.
Is there some setting or configuration that I am missing or is it that wifi is not enough and mobile data/roaming is required?
My concern, of course, is that T-Mobile will press the issue if this scenario continues.
Thanks in advance
Sorry we can't increase your limit. We need $100,000 first before we can proceed. Please send me a dm and I will give you my bank info, for you to deposit the money. Once the money has been deposited, we will increase your limit.Zong dcb limit is very low please increase daily limit from 10000 to 50000
Got an Android head unit with no physical buttons (has 1 tiny reset hole only). I was playing around with developer settings and enabled Simulate Secondary Displays with 4K option. Unfortunately this lead to the simulated display overlay taking over the entire screen with no way to get rid of it as the touchscreen is not unresponsive over the overlay. As a note, USB debugging mode was not enabled on the headunit prior to this happening.
I've hooked up a USB keyboard and have managed to get to the app drawer but can't seem to find a way to scroll through and select the "settings" app. Pressing 'TAB' or the arrow keys don't seem to be able to cycle through the app drawer.
If anyone could help with any of the 3 solutions, I would be grateful:
Thanks
- How to navigate through app drawer to get to "settings" app on android via USB keyboard?
- How to bring up the android search bar with the keyboard only (that way I can search for "settings")
- How to boot up android headunit in safe mode (tried it on my mobile phone and was able to disable simulated display once in safe mode). However my headunit has no physical buttons.
I'd set your expectations a lot lower when using Bluetooth for things like sizable file transfers. It's foundation is based on low power so its bandwidth speed is limited accordingly. Last time I read Bluetooth v5.x would provide up to 3 megabit per second bandwidth, substantially less than even a low speed WiFi connection at 54 megabytes per second (don't forget, it takes 8 bits to equal 1 byte so it's almost no comparison between the two,)
Bluetooth in smartphones is intended to be mostly for communicating between devices, not file transferring. Instead, wouldn't something like WiFi Direct be a more suitable option? An ad-hoc, peer-to-peer WiFi connection will be better for exchanging files than Bluetooth, and most modern phones support it already.
https://www.digitaltrends.com/computing/what-is-wi-fi-direct/
most likely you were moving in and out of coverage on the train and the whatsapp server could not detect you and thus the offline status. does this happen when you are not traveling? if the answer is no, then just tell her it was a one off situation. if it keeps happening then check your cell signal, and see what kind of coverage your are getting. if you are on wifi, then check your router. it may need to be rebooted.Hello to all!
I have a big question and the right replies will help me a lot (more thant you should thinks...)
I live in Italy and Ive a 5g Zte 72A smartphone.
This morning I was on a train and my signal wasn't perfect and I think It's normale during a train trip...
What's happened? That my gf wrote a message, I've replied normale but she goes crazy because, she says, I've modified my status to offline in privacy settings.
I'm an old guy and for me WhatsApp It's like a SMS service upgrade with photos and videos and files uploader and I think It's Always online because you write me and I receive your message. I never changed this setting because first before today I didnt know that and second I didnt modify NOTHING.
How It's possibile that She saw me offline but I was online because Ive never changed my settings? Glitches, bugs, WhatsApp down of two days ago??
Thanks a lot for all replies.
Everytime my phone get an update notification, there's always two options: first option is download the update, the next one is delay which will make the notification vanish and reappear few days later. That would mean my auto update is disabled right? One more thing is before the problem occur, my phone last update was from May 2022. When the device got in Safe mode trouble, I ran an update check and update my phone to latest version (September 2022).
