never used alexa really. nor google assistant. but which music player does alexa use to play songs? play music or prime music? check their permissions, if it is one of those.
There are many problems that I need help with.
there used to be many mod versions of whatsapp app. If I use it on an Android device, it says it's not working.
But Yo Whatsapp version 9.41 is usable.
Do not know when using it has any effect?
Because it's not on CH Play.
https://whatismyphone.net/vendors/asus/k011
Throw it in the circular file.
Most likely will not run anything current.
HahahaaWhat ? I plan on giving it back when I am done borrowing it ...
Hi there) I use parent control on my sons phone, but he managed to find a way how to avoid it. Maybe someine knows some more stonger apps, which he won`t be able to hack?
welcome to AF!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!oh welcome to this site, I use apple and android products either. Don`t see a problem in this cause all products have differnt features and some gadgets are better by apple and some by android
