Unlock question
My understanding is that carriers will only give the unlock code to the account holder, so if you buy a phone from someone else who tells you it is unlocked when it isn't you are out of luck. That was probably your situation when you called asking for a code - though of course they could have explained that without hostility (though I can imagine many ways in which that can be a crappy job).
But yeah, normally you need a code. I suggest you test it with a non-ATT SIM (to be sure don't use one from a virtual operator who use ATT's network either), and if it doesn't work get back to them and tell them you never received the text/email. Whatever you do, make sure it is unlocked while you are still a customer with them, because if you end a contract there is no guarantee they'll give you the code after that.
Help How to disable blinking notification icon in peek display?
Have you tried it with Safe Reply off, I'm sure you have.
I have an older E6 elsewhere but also have you tried the Moto or *Device Help app (if there) for the setting.
Also, though the same model, some settings or the Moto or *Help (iirc) app may have updated in the newer one. You can compare the version in Settings - Apps.
Not much help, but hopefully someone with a Moto will respond.
*I see the actual app is called Device Help on my E6 (no Peek Display)
Help Add New Apps to Home Screen?
Your Note 3 is running Android 4.x (KitKat) or 5.x (Lollipop) isn't it? Your Z Fold 4 is running version 12, yes? Don't expect your Note 3 to have the same feature set as your Fold -- there's a more than significant difference between those two models as far as hardware configurations, the operating systems, and the user interface options.
Try what @Dannydet suggested, install and configure the Nova Launcher app on your Note. Or just keep using Samsung's TouchWiz launcher, and remove the apps you don't want on the Home screen when you finish setting up your Note for your trip. Is it that much of an inconvenience? How often are you going to be installing new apps once you're done setting things up?
Hi
It isn't really much of an inconvenience at all. I just wanted to set it the way I described if the option to do so was there. It would be a convenience feature that would be nice and that would allow my phones to operate similarly. In short, I thought I should at least look to see if the option was there, then use it if it was. If not, no big deal. I'll remove the added apps as I install them. Come to think of it, I vaguely remember when moving from the Note 3 to Note 8, the Note 8 behaved differently here and I thought it was odd at the time. It was set to not put apps on the home screen. I looked on the home screen settings again; nothing there. I also looked in the general settings again. I found nothing, so, as mentioned, that option must have come about later.
Danny
How can I update UK SYGIC maps
Right, I will attempt to answer your many questions and hopefully put my plight into context, equally my eyes are not so young either, in fact last time I looked, I think the date stamp is 1940!!!As for my car which is also my baby and my old age toy, is a very resplendent 2002 Wedge wood blue Rover 75 connoisseur V6, with the well-loved 2.5 Lt petrol engine. Documented mileage of just 45670.Full service history.
Since owning it I have kept it up to date, and as it is in fact a BMW build, I fitted the plugnplay BMW E46 full media unit, which has two dedicated mini-sd slots one for media and the other for GPS (Sat Nav).
As for finding developers, suppliers, etc of mini sd sat nav cards, the web is full of them.Audiotechdirect.com, Senitech Satellite -Face Book, GPS Android sat nav. Satnavishop, and the most obvious one Ebay!
Most based on Sygic and Tom Tom systems. Incidentally all of these suppliers only deal with Android, which is why 2021/22updates are difficult.(Plus Although they supply sat nav systems via sd cards they do not issue updates!!) Cost of cards between £21 and £39.
My vehicle add on Android media unit BMW E46, came with IGO sat nav on a mini sd card,but I couldn't get on with it, so I obtained the free Sygic system (purchased the further options I required) and its worked well, but its now out of date
Now both Sygic and IGO put out free updates,
IGO is simple,you download the android update, insert your mini sd card into PC remove the out-of-date material from the card, and replace it with updated material. But with Sygic its different, they only download free updates to PC for phones, not ANDROID automotive devices. I have been on to Sygic who were really helpful, but do not issue updates for Android sd cards!
Equally link given by:
mikedt (from China bless him) would only update devices not sd cards. Also your link ,only explained how to transfer Sygic from internal storage to sd card,but no updates.
So it might be, I return to IGO, as it appears sd card updates for Sygic are not available.
4g status goes away with wifi enabled.
Your phone uses one of two ways for online access, either WiFi or cellular. They are both wireless signals but are two completely different types of wireless connectivity.
-- WiFi signals are relatively weak with an effective range of a few hundred feet or so. Your home router emits the WiFi signal for your home network. Your router is connected to your ISP's modem and the modem is what is indirectly connected to the Internet. WiFi is often identified as 2.4 GHz or 5 GHz, both being direct references to the bandwidth frequency each on occupies (i.e. channel 11 in 2.4GHz is 2462 megahertz, channel 1 is 2412 megahertz)
-- Cellular signals are pretty robust and have a coverage range of a few miles. They are emitted by cellular towers/cellular access points scattered everywhere. All of those are fed their signals by nation-wide cellular networks, and those are indirectly connected to the Internet. Cellular can be differentiated by progression levels -- 2G, 3G, 4G/LTE, 5G -- a marketing abbreviation for 2nd Generation, 3rd Generation, etc.
Some people mistakenly merge both together since both are wireless and oddly because there's a common letter G in those identifiers but in reality they are two very different types of wireless connectivity. If you do prefer to consider both the same, that makes your problems with online connectivity a lot harder to fix.
In your instance, there's not really a problem. It's a just a typical way smartphones work -- when your phone is receiving both a good WiFi and a good cellular signal, the preference is to prioritize WiFi over cellular. Just disable WiFi or disable mobile data in accordance to what your need. (disabling mobile data doesn't cut off cellular connectivity, it just stops any active data exchanging over cellular. A very low bandwidth cellular connection still remains so you still can receive and send phone calls, and SMS texts.)
Apps MySQL connect and query
Hello dear helpers,
I'm new to app development and with the help of a youtube tutorial I started an app that should connect to an SQL server and query data, but now I get an error that I can't sort and hope for help from you.
Code MainActivity.java:
Java:
package com.huth.system;
import androidx.appcompat.app.AppCompatActivity;
import android.os.Bundle;
import android.util.Log;
import android.view.View;
import android.widget.TextView;
import java.sql.Connection;
import java.sql.ResultSet;
import java.sql.Statement;
public class MainActivity extends AppCompatActivity {
    Connection connect;
    String ConnectionResult = "";
    @Override
        setContentView(R.layout.activity_main);
    public void GetTextFromSQL(View v)
        TextView tx1 = (TextView) findViewById(R.id.textView);
        TextView tx2 = (TextView) findViewById(R.id.textView2);
        try {
            ConnectionHelper connectionHelper = new ConnectionHelper();
            connect = connectionHelper.connectionclass();
            if(connect!=null)
                String query = "SELECT * FROM `app`.`app_user` where id='1';";
                Statement st = connect.createStatement();
                ResultSet rs = st.executeQuery(query);
                while (rs.next()){
                    tx1.setText(rs.getString( 1));
                    tx2.setText(rs.getString( 2));
            else
                ConnectionResult = "Check Connection";
        catch (Exception ex){
            Log.e("error2", ex.getMessage());
Code ConnectionHelper.java:
Java:
import android.annotation.SuppressLint;
import android.os.StrictMode;
import  java.sql.DriverManager;
public class ConnectionHelper {
    Connection con;
    String uname, pass, ip, port,database;
    @SuppressLint("NewApi")
    public Connection connectionclass(){
        ip= "*******************";
        port = "*****************";
        uname = "*************";
        pass = "****************";
        database = "************";
        StrictMode.ThreadPolicy policy = new StrictMode.ThreadPolicy.Builder().permitAll().build();
        StrictMode.setThreadPolicy(policy);
        Connection connection = null;
        String ConnectionURL  = null;
        try{
            Class.forName("net.sourceforge.jtds.jdbc.Driver");
            ConnectionURL = "jdbc:jtds:sqlserver://"+ ip + ":"+ port+";"+ "databasename="+ database+";user="+uname+";password="+pass+";";
            connection = DriverManager.getConnection(ConnectionURL);
            Log.e("error", ex.getMessage());
        return connection;
error massage:
E/error: I/O Error: Unknown packet type 0x63
pls help me :)
Filter
