I get errors when I create a new project in Android Studio
- By James_Watson
- Android Development
- 9 Replies
It started to work when I reinstalled both windows and Android studio.
It seems to be a development environment issue.
correct DND is only for notifications and its sound.....everything else will run as intended depending on the app.If Do Not Disturb is enabled, is it all functions of the app is still working like normal, only notifications is muted (notifications do come in silently in notifications panel)?
no google apps will not be in the windows app store.......except maybe youtube.Is it all google apps are not available in microsoft store? I did not find Google calendar and Google drive app there.
you mean Lookout....i think....LOLI am with you guys on that. Its just that Outlook has this "scream" function that makes a loud siren noise even with the ringer off which was perfect for helping my perpetually phone-losing relative find their phone wherever they left it last.
But, I cancelled my subscription last night anyway due to all the trouble.
It'd been several years, and many people have emailed them. They have no real interest in control support, it seems. I honestly figured that'd be the answer, but I was hoping there was an app to map touch to controller. Where it could emulate a directional swipe to joystick direction. Basically, hoping even though I didn't think so. Haha.I'm pretty sure you can't. The dev either built the game so it could use a controller, or it doesn't.
For Dragon Quest, the devs are Square Enix, who maybe able to add controller support to their game with an update possibly? Might be worth you emailing them about it.
Does anyone know any good music streaming app that also works as a music player?
That seems like a weird site to block.I'm just seeing a your IP address is banned message from that website.
