Help pls
so the things that you mentioned in your op are not symptoms of hacking. hackers mostly want to infiltrate a phone and steal info whether it is your contacts or your identity. they usually do not do things like make a popup disappear or mess with your flashlight on your phone. hackers want to be discrete and steal info from you.
as mentioned a factory reset and setting up a two step verification on all accounts that has that option is the best way to protect your info from thieves. i would also change all of your passwords to any accounts you have.
and whatever you do, never give your phone to someone and leave it with them unattended. unless you are going to get it serviced or fixed at a reputable place.
Help Show Recents screen as list in Android 11?
This is nuts. I'm really surprised that virtually no one anywhere is talking about this.
The change was made a couple of years ago. To be honest I don't recall much controversy at the time, so that's probably why there's no discussion about this now.
(Personally I find it useful: I can read information from the preview so I don't have to switch apps to remind myself of something. Though for quick app switching one of the older "grid" layouts with 8 apps/screen was faster - I never found the "rolodex" style either attractive or useful, so never once missed that).
Android 12 - how 2 remove announcements area on home screen
Doesn't Android force you to enter your PIN or alternate password after so many hours/uses of biometrics or is that just a Samsung thing? The only thing I got running Stock Android is a Walmart tablet running Android 11 and it ultimately forces use of the password over face unlock after so many hours. So it's not just a 'tap sensor and never see lock screen'
Often I look at my lock screen to check notifications since they got rid of the convenient notification LED (Why?!) so when I have to see it it might as well fit me, and Android 12's doesn't fit me. As far as I am aware, no replacement lockscreen can change the notification shapes at all. They add features and modules like Good Lock but you're stuck with whatever crazy scheme Google's cooking up at that time otherwise.
Believe me, I'd love to change everything. If I could bring back the classic Gingerbread stock slide to unlock UI on a modern phone I'd have done it by now.
Do you know about Telegram?
Yes, you can uninstall the app, and reinstall another version.
Your account will still be there, and you will need to log in.
The web version should be uncensored, but that could depend upon what browser you use.
I stay away from Google as much as I can.
Google and Apple both censor the Telegram apps available from their app stores.
Telegram is forced to accept this if the app is to be on these stores.
[Free][Game] - Panic Quiz Game - Android / Google Play
Hello people.
I had a game published back in 2016 and it got the whooping 1000 downloads
so I decided to polish it a bit, to add some new questions and conditional logic aaaannd... here's the new version:
Google Play
I'm not a professional developer, just building stuff in my free time, sometimes.. last time was as I said 2016
So, please don't be too harsh with the reviews and stuff.
I hope some of you might have some fine moments in the rest room with my tiny quiz.
Here's few screenshots, just to check if the colors and design match your liking without clicking on the google play link for no reason. Including the simple rules of the game screenshot. * image quality here might be lower than actual in-game stuff.
Reading a review on google play or replies here will make me very happy.
I'm not a very social person IRL, so yeah.. you know I guess.
Thank you and be well!
Screenshot_2022-08-11-16-09-59-005_com.valeriev.panic.quiz.game.jpg Screenshot_2022-08-11-16-10-13-975_com.valeriev.panic.quiz.game.jpg Screenshot_2022-08-11-16-10-25-532_com.valeriev.panic.quiz.game.jpg Screenshot_2022-08-11-16-11-33-960_com.valeriev.panic.quiz.game.jpg
[Solved] XT-2115DL Moto Stylus drops usb connection when file transfer initiated
It's not about how fast the current goes, but how much current there is. Twice the length of a given wire has twice the resistance. So for a given voltage (V = IR) the higher resistance results in lower current.
I would guess it only happens upstream because the phone's power supply is much weaker than a desktop pc's. In any case the .9m cords work perfectly (the old one was 3m)
Replacement accessories
you can always get the oem chargers and cables from samsung if you want:
https://www.samsung.com/us/mobile/m...travel-adapter-black-ep-ta800nbegus/#benefits
you can also search for the cables if you need it.
.....but.....
i'm with @olbriar you do not necessarily need oem(original equipment manufacturer) chargers and cables as it says in the manual. they are just trying to sell their own product. i have used many chargers abd cables from different devices to charge my phones before in the past. just be careful of cheap chinese made products. they tend to break or not charge your phones properly.
Turn Off Motorola Automatic Software Update
At first, my friends and I were also bothered by these automatic updates. Especially when you have already set up to work in the same way on different OSes, and after the update, you have to adjust to the new trends, even if they are improved somehow. Fortunately, we were told that Zaptest has a usability testing tool, and our corporate system will work correctly after the updates. It is not always possible to safely block updates so as not to harm the well-established work of the team. But if you are annoyed by updates, try blocking them, as shown in the screenshots.
Help How to buy Samsung with 4G VoLTE in Europe? (No foreign phones work in US at all now??)
AFAIK all you need to do is to unlock it, is to make one phone call of at least five minutes using a local SIM within the region,
why do you particularly want to buy and import a German(EU/EEA) variant of the A22 or A32 into the US? That may or may not work with T-mobile rather than the unlocked US variant of these devices, that's guaranteed to work with T-mobile..
Re:- the thing with just making one 5-minute phone call with an EU SIM card - note that I asked Samsung support, "Do you mean to tell me that EVERY SINGLE ONE of the millions of Samsung owners in Germany (surely all EU) who travel outside the EU, have emailed Samsung their travel dates, copy of receipt and IMEI number THREE WEEKS IN ADVANCE in order to use their phone while traveling?" and they said, yes, every one of them has done that. It's the only way to use an EU Samsung outside the EU. No exceptions.
Then I tried support again the next day and they said that's wrong; you can email if you need to but you can also just do the 5-minute call and he explained how it's all about preventing people from buying phones and reselling them on other continents, which makes you wonder, who is buying phones *retail* in the EU and reselling them in some continent where you can't even get them?
Not importing - I live in Germany and will be traveling to the US.
Android auto doesn't show up on the car's screen
I don't know what head unit is. My car was born with android auto. And as I said, it's working fine with same cable and my wife's old Samsung
here in the states a head unit is the car stereo. so is this factory? some units that have older software will not work with newer phones. but android auto is going away thanx to google discontinuing it.
here is a similar thread from this forum with links that explain why:
https://androidforums.com/threads/android-auto-stopped-working-on-galaxy-fold-3.1342789/
Funnel substitute
I wouldn't call myself one of their big consumers. The local BB&B is not really very local to me. We have shopped there and have never been disappointed in the selections and quality of products they offer. When daughter #1 left home we sent her off with most all of our kitchen tools and silverware. We replaced all of that stuff at BB&B and most of it is still in use.
Exactly! I remember buying my daughter her first few pieces of Calphalon cookware at the store in Dallas; I bought all my original Calphalon there, too, and it's still in use. It has a lifetime warranty, and I actually made use of it once. We had followed its cleaning instructions to the letter, but something got burned on and would not come off. They replaced it just like that! I've added a piece here and there over the years. I love Calphalon and even though I'm rarely the one cooking these days, it's the only brand I buy. I guess you'd say I'm a loyal customer. :)
Filter
