Hey,any chance you could help me out with the same? The link appears to be dead.My Uncle had this problem, and I found a way to recover the files. The .tec file has the same pixel density as the original .jpg, only in the wrong format.
I've written a Java program to automatically restore the files. You can get it from my website here: thebillington
Hope this helps if you still have your .tec files!
thing is that was an old free version for android - Im sure the new Paid version works perfectly !!I found Android TV to be pretty poor with app compatibility. And Bard's Tale is a pretty intense app so I'm not surprised it doesn't work.![]()
No issues on my z fold 3 with using voice and keyboard. I mainly use voice for texting when I'm driving or when I use maps.
I am interested in the caps only feature because I am using Android mobile barcode scanners in my manufacturing plant. The workers using these devices, which look like robust thick mobile phones, use a website that is part of our ERP system that they do transactions in. They have to tell the system when they are moving parts from a bin to another bin and all the part numbers and bin numbers are capital letters. So if the keyboard is not auto capitalized, you have to constantly tell it to make everything capital. These devices are used for nothing else. So if you all needed or wanted a legit use reason, there it is! I was gonna try Fleksy but also read it’s Russian and different? Is there really not a quick easy way to make this happen?
I am looking for an adblocker app for android which is not automatically blocked by qustodia. Would anyone be able to advise me?
ahhhh that makes sense. thanx for clearing that up.I think the OP meant for if his own car was involved in an accident. And was referring to the Google Personal Safety app in the Play Store, that is for Pixel devices only.
https://play.google.com/store/apps/details?id=com.google.android.apps.safetyhub
"Car crash detection – get help calling emergency services after a car crash. If your phone detects that you've been in a car crash, it can call for help automatically."
Which is interesting because all my phone does if mobile data is off is tell me that I don't have a connection: I don't get an easy to accidentally hit "turn data on" button.I don't understand.
I have the data option disconnected too.
I refer to don't receive messages asking me to enable data connection.
1: Drop down notification menu:
One of things I liked about my older android models was that when notifications came in, and I pulled down on the desktop drop-down menu, I could click on any one of the notifications and it would go to that app, messages, email, website, etc, and also clear it from the drop down menu.
Now when I click on these notifications it merely clears them from the drop-down menu, but it doesn't take me to the app or website that the notification is alerting me to.
2: Maps:
Apparently my google assistant is using a different version or different path to maps, than my google maps app. Example: When I go directly to the maps app, I can enter text, or use voice typing in the search bar for things like, "Pizza near me", and it will default to my current location, and show me several options.
But when I "Hey google, show me pizza near me" it always defaults my location to my house, (Where I am understandably signed in on google), and the map looks like it is in night mode.
Are these two different maps? Older versions of android google assistant "Hey google" I've used would always default to my current location using GPS, and the map never appeared in night mode.
3: I mentioned this before, but I still haven't found a way to connect my "Hey google" command, with my chosen clock and alarm app, "Alarm Clock Extreme". When I say "Hey google! set a timer for 5 minutes" it always defaults to the android 12 stock app. I considered disabling it, but think it might mess up other apps or the phone in general.
These are all luxury problems I know, but the details....... Lol.
Thanks!
PM
