Moving an album via USB link to pc
- Smartphones
- 13 Replies
I like what you mentioned about this too, it is much more easier, screen shots and have them in a different subfolder on accident, or have them to a different folder that is visible to you, funny how my Gallery app just adds in different photographs I have snapshot and show them in my phone, but when I get super freaky and not have it all over the place, then it is a gather throughout the masses of my downloads.Since I have an s21 I just tested what the Samsung Gallery app let me do. And I agree they've not thought it through:
I selected a couple of photos and then chose the option "copy to album". I chose "create" and it gave me the option to enter a folder name, but gave no visible way of choosing where that folder would go within the filesystem. It actually create it as a subfolder of DCIM, but I had to use a different app to find it!
I was able to copy photos to a folder of my choice, but only via the same "share" trick I had to use with Google photos: select photos, choose "share", find a file browser in the options to share to (involved some side-scrolling, no clue in the UI to tell you to do that) and then use that to create and select a folder where I wanted it.
Bottom line: it's possible, but they don't make it easy. This sort of thing is why I generally use third party apps for most things rather than what the manufacturer bundles - I can usually find something that does a better job (or at least one that suits me better).
I must've posted in some other thread... Anyway, my helper--with no input from me--decided that a nice Keurig would be a lot better. And bought it for me. I hadn't complained or anything about the little one I'd bought, but it was rather limited, and the Keurig is much, much nicer.
