Unwanted googooization of file manager
- By ocnbrze
- VIP Lounge
- 1 Replies
never heard of simple file manager......sounds like it installed some crapware app cleaner which are not necessary. the only true way to delete the cleaner app is to wipe cache and data for simple file manager, and then uninstall it. it needs to be done in this order. sometimes when you uninstall and app, its cache will not uninstall with it. and sometimes those leftover cache and data could still have some kind of crapware.Recently I went to a video on sd via Simple (?) File Manager. I don't know how but it has apparently been colonized by goohoo. I retried that and another video, only to find that the horror of their file app/cleaner had metastasized. How do I get rid of this thing and return to normal?
i would do the same for the app cleaner....that is if its still there.
I must've posted in some other thread... Anyway, my helper--with no input from me--decided that a nice Keurig would be a lot better. And bought it for me. I hadn't complained or anything about the little one I'd bought, but it was rather limited, and the Keurig is much, much nicer.
