Help post-update issues
I've been in contact w/the carrier (Consumer Cellular) two more times (a total of 4 calls + one chat), and I've visited the tech at the local Target store in addition to posting here. CC tells me they've gone thru all their troubleshooting steps and they can't help me.
Currently all that is obviously wrong is that I can't send/receive texts over 144 characters, and I cannot send/receive images via text. This is crippling to my normal usage of my phone.
CC also says because my phone was originally a Verizon phone they believe it may no longer be compatible with their system and suggest that I purchase a new phone. Sorry but at almost $1,100 and only 2 1/2 yrs old & working perfectly until CC updated their network around 3 weeks ago, I'm not replacing the phone due to changes in their system!
Any further suggestions are welcome, including new carriers tho I don't want to go with any big-name corporations.
Your device is not compatible with this version
Download the other version of the app. I used to do it in Google Play but I can't now. I don't know why. Maybe they just remove this function but I think you should try this on your smartphone. If it's impossible you can use unofficial site. I know that it is not very properly but it helps when I really need its help.
But the problem is that the op uses a phone that runs on the Android Go. It's different than normal Android phones.
Wear OS and mobile native app debugger issues
Hey guys
I've created an android application with a wearos module contained within it. This might be a rookie issue given that I'm new to android development (I'm from a web dev background) but I'm struggling to get my wear and mobile apps to communicate, when they are in debug mode.
Basically, I have written some code in the mobile application to detect if the wearOS app exists on a connected watch, and if it does, allow the user to monitor the sensor activity on the watch.
When I run the mobile application debugger on a physical device through USB, I see it doesn't package the wear application with it and so I cannot install the linked watch application on my watch (which is linked to android studio through ADB over wi-fi). While the mobile device debugger is running, I run the debugger for the watch app too and the app then runs on the watch, but it doesn't look like the code in the app is actually detecting the watch. This functionality does work though when downloading the published app through the play store, and then installing it on the watch through the play store too using the 'apps on your phone' menu on my watch.
How can I achieve the connectivity between the watch and phone apps through the debugger? This is a massive pain point for me and I can't seem to find anything online that addresses this and that describes how best to set up debug environments so that these apps are linked on the 2 devices and can communicate in debug mode. My mobile device app is heavily dependent on detecting watch sensors and interacting with them and so I need an efficient way to test this.
Thanks!
nothing working on s20fe
It looks like the "nothing working" items are all root mods or apps that require root. So applying William of Occam's famous principle, the single explanation for everything that's been described would be if the rooting itself didn't actually work. That may be wrong, but from the information given so far it's the simplest explanation. So please provide as much information as you can about what you've done, including what tests you've done to confirm root, and what exactly happens when you try to do the things that don't work (and how you do them)?
As said above, the commonest reasons people install Lucky Patcher are things that the forum rules forbid discussion of. Hence specific help with that app is difficult to offer, but I suspect that dealing with your problem in general would resolve your issues there.
SAFE MODE
How do I boot my mi phone into recovery mode?
Press the Power and Volume Up buttons at the same time. Then release the Power button first when you see the white Mi logo. Don't release the Volume Up button until you've entered the Mi-Recovery mode.
This Mode was easier to get into than Safe Mode.
I was able to get into Safe Mode once only and I wonder if it's because my phone does NOT show Redmi Note 7.
My screen shows Redmi - then MIUI comes up. Very tricky.
I did get into Safe Mode again but it reminds me of the Samsung Galaxy S4 trying to get into safe mode>
FINGERPRINT UNLOCK DOES NOT WORK
Hi, sorry I'm late in my reply.
The operation to set the Fingerprint Lock takes quite a few minutes. You are first required to set either a Pattern, PIN or Password. This is essential to be able to unlock the phone if your Fingerprint is not detected. When you are told to place your finger in the detector on the back. Then your finger print is shown on screen, you will feel a vibration - remove your finger - then place it back in the same place - another vibration - and you keep doing that and following the onscreen instructions until you see a large Check mark (Tick) on the screen.
This operation will take quite a few minutes as the whirls on your finger are recorded in several sequences. the final operation before the big tick is to move your finger around in the detector to enable full recognition of your fingerprint.
IT DOES WORK!!
Hope this helps as I did this when I first bought my phone and thought that one placement of my finger was all that was needed. WRONG!!!
The instructions above will enable the Fingerprint Lock to be set correctly.
Further clarification:
When the phone goes to SLEEP, the fingerprint lock will open the phone for you.
If the phone is switched OFF ( Powered down) and you Power the phone on again, you need to use the PIN, Password or Image you created to UNLOCK the phone.
Compromised Galaxy S10 and Knox.
Yeh, it sounds like you got a few problems there.
But if the phone has been rooted and compromised by undesirable third-parties. Definitely replace it with a new phone that isn't rooted, and do NOT let it out of your sight. and do NOT let any other person plug your phone into their "Kali Linux laptop" or whatever.
Also suggest you make new accounts for it as well, e.g. Google etc. Use good strong passwords, and enable two-factor authentications.
Help Multiple google accounts
Hello everyone who answered me I'm sorry I haven't answered and said thank you for the replies but for some reason my notifications stopped coming to my email and I thought I had only had the first couple of replies. So thank you.
I have taken it all on board and seem to be getting somewhere a bit now.
I'm also totally hopeless at posting on forums so goodness knows what will happen when I get going.
Also, I am looking for a very large Android phone
at the moment I have got a Huawei 20 x which is huge but I need to replace it.
but I'm wanting to go for something with a stylus like the new Samsung S22 Ultra which seems to be about the biggest I can see.
there doesn't seem to be many about that are actually advertised as being able to use a stylus.
I don't know if you can use a stylus with most phones if they are touch screen???
Can anyone point me towards a huge smartphone, preferably with a stylus or capability for, if not with a stylus then just a massive phone, 5g and at least 128gb?
[Free] [App] Custom Aim - Crosshair Generator Pro
Custom Aim - Crosshair Generator Pro helps you to change crosshair in all shooting FPS games. Create a custom crosshair overlay in any shooting game to accurately aim & shoot your targets or enemies. Change crosshair and become a professional sniper shooter with the best free Crosshair Aim Helper
Custom Aim - Crosshair Helper & Aim Controller adds a customizable virtual overlay pointer on your weapon controls to seamlessly aim and shoot in top FPS shooting games with accuracy. With over 24 available crosshair style, change crosshair on your favorite shooting games to boost your aiming skills! Use this simple lightweight crosshair tool while playing your favorite FPS games to improve your sight in any FPS game and shoot with custom aim.
Features of Custom Aim - Crosshair for FPS Games
Unlimited Crosshair Designs
Choose from a wide collection of crosshair designs to add as an overlay to your shooting FPS games, that make your shooting aim much more precise & accurate.
Customize Crosshair for your FPS Games
Customize crosshair designs according to the games you play. Track the games you played and customize your crosshair designs. Bored with the default crosshairs? Use Custom Aim - Crosshair generator app to change the crosshair of any shooting game. Adjust crosshair size and choose any color that you want and customize the crosshair designs the way you want! Adjust the crosshair position to fit on your weapon controls & improve shooting skills. Custom aim is the best tool to change Crosshair for games and it helps you to focus on your target.
Generate Crosshair on Unsupported Weapons or Guns
Custom Aim - Crosshair generator app, makes custom crosshair for your guns & weapons that help you to shoot and aim accurately to target and kill your enemies. Custom Aim generates free Crosshair designs for all shooting games, even if your weapons do not support crosshairs.
All Games Supported
Custom Aim - Crosshair Generator supports almost all popular shooting FPS games to change the default crosshair designs of your game. Crosshair Changer supports all major shooting games, Action games & FPS games. Use the Free crosshair changer app to enhance your shooting &
aiming skills and let the Free Fire
Improve your shooting skills and test your reflexes & tactical skills with the best crosshair app to make shooting easy & fun. Create a custom crosshair style and adjust its appearance. This is the best crosshair aim app for shooting FPS games that makes it the best aim helper app. It also helps people with weak eye sight to play FPS games by adjusting crosshair size options. Make yourself the best player with this crosshair practice in all first person shooter games!
Download Custom Aim - Crosshair Generator & take headshots like aimbot PRO! but in an ethical way!
Download The App on Google Play: https://play.google.com/store/apps/details?id=com.itdeveapps.customaim
Filter
