I like to buy a celeron laptop...
https://www.amazon.com/PiPo-W14-8GB-Ram-128GB/dp/B08R29G3R9
can I run Android Studio with it? is it possible? thanks...
I've not used this myself, but from your screen-shot, that looks like it might be the STOP button. As the square icon is usually for STOP in these sort of things.
even though it supports higher android os, it might not be available due to your cellular provider. your provider in conjunction with the manufacturer are the ones that makes updates available to your device. your phone is 5 years old! so i'm not surprised. if it is says it is up to date than your phone is up to date. not much you can do at this point in time.I've recently bought an used Xperia L1 (in very good condition, looks like brand new) to use it as a secondary phone.
The only issue is that I can't update it to Android 8, even though, as I found on the internet, Xperia L1 supports it. The device, which runs Android 7.0 (https://imgur.com/a/5UcEjyY) just says it has the latest available system updates (https://imgur.com/a/FX04B5i).
How can I solve this problem?
It all depends on the eye.Some great advice here Hadron, I've tried 2 of the 4 things mentioned. I do wonder if buying an actual camera will be the thing to solve color issues. But I fear it will be yet another waste of time and money. BUT it is certainly worth thinking about. I beleive I've tried another camera app on a previous phone with the exact same results, however I haven't done so recently. I'll give that a go first, just in case it works. I don't hold hope, but it MIGHT work. Dang, I knew this was probably not fixable....I sure hoped though.
I'll keep trying and I greatly appreciate these ideas. Who knows? Never give up, never surrender!!!
Actually it does. FRP gets tied directly to the installed Android OS on the device. It's software, it isn't some magical process that writes itself permanently into a chip on the phone's logic board. Perhaps you're confusing Factory Reset with flashing ROMs? All a Factory Reset does is wipe the user data partition clean, it doesn't do anything to any of the system partitions (where the OS resides). So no a Factory Reset won't bypass FRP. Flashing the ROM does replace the existing, installed OS with a 'clean' one.Flashing a ROM will *not* remove the FRP lock. It wouldn't be a very secure lock if removing it were that easy
I learn something new every day!!Open Gmail app, tap the 3 line menu in the upper left. Scroll down to settings and then choose your email address in the settings. Inbox notifications > select the box for "notify for every message".
View attachment 161919 View attachment 161920 View attachment 161921
