Android tablet model m729b
HI I'm having a similar problem maybe someone can help me with when I go to turn it on the mini android guy come on then a bit of info in the lower right corner (Android OS 4.0, Kernel 3.0.8, Build # V1.5.1, then after a few seconds the info goes away & the droid stays, until I hold the power button to turn it off, & it appears as if the antennas on the droid are slightly brighter on the ( right side as it's looking at you, but it's actually it's left side if it were standing in front of you) theirs no noise or vibrations as it coming on. Does anyone have any helpful suggestive advice on what to do?? Thanks...
Best App for Organization
A lot of information on the Internet and have to filter a lot to find exactly what you need. And there are millions of people working on applications to please everyone. It's all about money. I chose Bank Logs for myself and read different information. I am very close to different hacker activities and I think there should be such kind of applications. They can simplify your life a lot. And I advise you to learn some new information every day.
Samsung J2 pro will not update software?
It's certainly possible that a low-end device might not have received any updates. All phones stop getting updates at some point, and budget devices stop getting them sooner. Samsung have recently become quite good with updates for their higher-end devices and even mid-rangers, but it's possible that a 2018 budget device that was only released in some regions might have been neglected.
But to check, I looked on Sammobile.com to see whether such an update existed. They list 2 SM-J250G variants for Australia, which they call OPP and XSA (neither of those obviously says "Telstra" to me). Both are showing 7.1.1 as the most recent firmware version. In fact, contrary to what GSMArena says, I haven't found any SM-J250 variant in any country where anything higher than 7.1.1 is available (the search interface doesn't let me look at a list of all variants in all countries, so I've just tried half a dozen or so, but it's the same story with all of them). So to be honest it's not looking good, especially since Android 8 came out in 2017 (so before the J2 Pro was released, though again it's not uncommon for lower-end devices to be released with older OS versions) - if they have not released an update by now it doesn't seem very likely (though my old Note 10.1 tablet did receive a surprise OS update after a 2 year gap - Sammy can be capricious about these things!).
Help Cannot find Android/data/com.android.providers.media folder.
I'm using LG V50 ThinQ, which runs Android 11. I thought my album thumbnails are corrupted, so I want to delete albumthumbs folder. But I could not found Android/data/com.android.providers.media folder on the app X-plore. Should I connect via computer to find and delete com.android.providers.media folder?
Voice to Text wo google?
Milo. Thanks. It took me a couple days of trying things and waiting for answers to tech questions to companies but none replaces the Voice to Text engine in android. Even Dragon dictates into its own notepad and then you would copy and paste that into your texting program. SpeechTexter does similar but also says that it uses the google engine for what it does. Well what good is that? That's probably why all these apps say they need network connection permission to operate.
Even if I could get the google engine to only work in offline mode only and not interact with google servers that would be acceptable but I don't see how to do that. Not that I'm doing anything secret just that I think it's a good idea to get google out of the loop in as many ways as possible, while, yes, still being on an android, even google, phone. Is there no way to do that?
Depending on how good of a speaker and clear your voice is, mine jumbles when speaking even to my google assisstance :)
Re: 3GPP
For the FE-ICIC and/or CRS-IC features, what does the channel estimation algorithm look like? Is the interference cancellation only on the interfering cell(s) only or are there multiple iterations that include both the serving and interfering cells? How many iterations/what is the stopping criteria? How is it different between colliding CRS and non-colliding CRS?
For the NAICS or other non IRC based techniques that suppress intercell interference, what is the receiver that is used? Is it iterative interference cancellation or a reduced complexity maximum likelihood (R-ML) detector? If iterative interference cancellation, is the decoder within the iteration? Are there any techniques in the iterations which are suboptimal but are meant to reduce complexity? If R-ML, which particular R-ML technique is used? Please provide details if you can about the specifics of the reduced complexity technique.
Same question as above but for the SU-MIMO and MU-MIMO receiver.
Thank you VERY much!
Filter
