[28/JAN/22] BVA9. 1st 2022 build. Bugfix update
- By ironass
- Smartphones
- 1 Replies
It would have been good if Samsung had included the February 2022 Android Security patch on this release and added One UI 4.1.
Yeah...no....I tried that before. I still ended up with tons of results that include the attached handheld shower. You'd think that would be an OPTION, right? One that you could filter out? But...apparently not....Try searching for faucets with the number of holes required.
The number of holes required for installation.
Exactly!
These 'updates' are nothing of the sort!
'updates', 'boosters' - what's the difference?
OK I saw online that something similar was being done to mess up iPhones and somewhere within 50 yards is a beacon that no one has claimed in the 2 years its been here. I wondered if it was similar because it looked like the wifi disable ssid was coming from my router since I can change from channel 1 to say 8 and the green one over the ATT network and the big blue one dissappear.
waiting for your response.
