Try. Tap phone icon upper right corner tap tap settings tap call alerts tap notify during callHas anybody found an answer to this problem mine and my husband's phone have loud dial tone noises during almost every phone call conversation he has the Galaxy Edge Plus and I have the Note 5 the caller on the other and can't hear it and I'm not pushing any buttons
You may be overreacting. A lot of cloth specially designed for eyewear is made of microfiber
I would like to remove the lock screen on my Pixel 3 Android 11. Unfortunately, I cannot find such an option.
Next I would like to place a few apps on the lock screen.
I have tried to look on the internet and cannot find a method for Android 11 and none of the other methods work on my phone.
Is there a way to do either of these?
This is the developer options menu on my European, non-carrier s21. You can see the OEM unlocking toggle about half way down. But it's unlikely that you will have this.
This doesn't give much details. Assuming that it is indeed your own personal Google account that's on the phone, there's absolutely no reason that you shouldn't be able to change the recovery phone number or email that you have on file. So when you say "to no avail", what error message is it giving you when you try to change the phone number?I tried to change the number within Google to no avail. Is it still possible to do a factory reset? I have no idea where Google got this number they think is mine.
