Junk Mail
They are chatty. I have United Health Care advantage plan. They are the worst at filling my box with trash.
I don't see myself getting anywhere near an Advantage plan, BUT in some states where they have minimal copays and minimal annual maximum out of pocket expenses, I would consider it. My state is like most states. Lots of out of pocket. SoCal, Florida and Oregon are three states that I know of that have good Advantage plans.
Help Is it safe to use no reviews app?
If you have more than one you are never sure...
Since meteorologists are never right anyway there is no 'sure'.
Some have better alerts or radar or features or layouts than others so all combined I have the equivalent of one good weather app for the five locations I watch. Besides, I just can't help myself!
Troubleshoot screencast of Moto G 5G
Not wirelessly unless you go the chromecast route. You can try hooking a USB to admit cable to the tv.
I'd check that the Moto supports USB to HDMI before buying the adapter (we know the TV has HDMI in, but that's all we know for sure so that's how I'm assuming you'd have to connect it).
A Chromecast requires an HDMI port to connect the dongle to and a mains socket to power the dongle.
Google deciding to drop support for an open standard in favour of their own proprietary one was a very Apple move, but it does show that these companies are all much the same.
Samsung Health
That does make sense if you're comparing different levels of sleep like REM, light sleep, restless, etc... you'd want the full length of time you're trying to sleep for comparison stats. It's definitely helpful to know how long you were trying to sleep vs. how much sleep you got.
It is indeed sad- but I'm not sure what that has to do with this post?
It's also sad when people are judgemental and lack empathy, without care or concern for the details and circumstances.
But it's all good. I understand the frustration but disagree with the venue.
Right, wrong place, I talked to you about this in another thread and you took accountability. I'm sorry if you were going thru personal issues, but over many years you have kind of done the disappearing act and we need you here. Water under the bridge at this point. I've said my frustrations and will love on. Please continue with the original topic of this thread moving forward.
Help Please Help: How to move SIM card from old phone to new phone?
I'm still struggling with my sim card size of: "Single SIM (Mini-SIM) or Dual SIM (Mini-SIM, dual stand-by)"
Here are the specs of the phone in case I'm reading the sim card incorrectly:
I just wish I could find an answer... 😢😢😢
I just came upon a SIM cutter device I'd bought about a decade ago when I bought a second-hand phone from Gazelle, and had to trip my SIM card to fit the "Micro-SIM" size. After nearly screwing the pooch, I got it to fit but it was wonky and finally I walked into a Verizon store where the agent happily gave me a properly fit Micro-SIM at no charge, since I wasn't planning to switch carriers.
Try reading this page for description of the myriad SIM sizes. Judging from the age of your phone model - discontinued in 2013, and the term Mini-SIM, your phone uses the old style "Standard" SIM card which telco carriers should be able to supply, although nearly everyone has moved their inventory to the ubiquitous "nano-SIM" which has the smallest border around the chip circuit contacts.
So my 2-cents is to not try cutting or trimming a SIM card to force a fit, just go to your carrier and tell them you need a proper SIM for your account, which you are going to maintain a subscription, and they will gladly send you a proper card that is programmed with your account information.
_____________________________
Super Grub2 Disk For Linux
Linux use to use a MBR program called LILO for booting into whatever OS you had loaded on your computer. It was real easy to use and write script to.
Then for some unknown reason, Linux distributions started using Grub. I had trouble with it starting on day one. It wrote over LILO and I couldn't get to my other OS to boot. I even talked to a guy who was some how involved in the testing of Grub and he couldn't figure it out.
The other day I loaded Fedora on one of my laptops and sure enough Grub didn't work. I searched the web and it was a common problem on the latest version of Fedora. I had to have the Fedora installation DVD in my laptop for it to boot to Fedora. I didn't even bother to try fixes that were listed.
Now I see Super Grub2 is out to fix Grub problems. I'm going to try on Fedora to see if it works. If Grub worked properly this Grub2 wouldn't be necessary.
Super Grub2 Disk
Filter
