Help Can't bypass activation
FWIW I've been using paid Express VPN for 5 years now, and had good reliability with it here in China, and some of my friends here also use it. I also recommend Astrill VPN, also paid.
I did look at Proton VPN, but their sign-up site keeps on showing broken CAPTCHAs..
Well, due to possible shady aspects of Express VPN I had to find something else.
I wonder what is up with the broken captchas?
I had no problems at all.
Can you make a screen recording showing what happens?
Apps Accessing phone GPS coordinates
You should be able to access the phone's location by querying the fused location provider directly on-device. You shouldn't need to run a bunch of queries against a costly web API. (I think; I'm not actually a developer, but I wasn't able to find any sort of pricing or limitations on using the on-device resources.)
https://developer.android.com/training/location/retrieve-current
Looks perfect. Thanks very much!
Arraylist Code Error
I have a problem with my code
package com.example.java;
import androidx.appcompat.app.AppCompatActivity;
import android.content.Intent;
import android.os.Bundle;
import android.util.Log;
import android.view.View;
import android.widget.FrameLayout;
import android.widget.ListView;
import org.w3c.dom.Element;
import java.sql.Array;
import java.util.ArrayList;
import java.util.Arrays;
public class MainActivity3 extends AppCompatActivity {
private static final String Tag = "MainAcitivity3";
@override
setContentView(R.layout.activity_main3);
Log.d(Tag, "onCreate: Started.");
ListView mListView = (ListView) findViewById(R.id.listView);
Intent intent = getIntent();
String asd = intent.getStringExtra(MainActivity2.namabarang);
String asdf = intent.getStringExtra(MainActivity2.jumlahstock);
Item sparepart = new Item(asd,asdf);
ArrayList[] itemlist = new ArrayList[1];
for(int i=0; i<2;i++)
itemlist = new ArrayList<Item>(); // initialize each element with ArrayList object
itemlist[0].add(sparepart);
itemlist[1].add(sparepart);
PersonListAdapter adapter = new PersonListAdapter(this, R.layout.adapter_view_layout,itemlist[0]);
mListView.setAdapter(adapter);
String number = intent.getStringExtra(MainActivity2.extraint);
if(number != null) {
FrameLayout lay = (FrameLayout) findViewById(R.id.frames);
if (number.equals("1")) {
lay.setVisibility(View.INVISIBLE);
mListView.setVisibility(View.VISIBLE);
} else {
else{}
public void onBtnClick (View view){
Intent intent = new Intent(this,MainActivity2.class);
startActivity(intent);
And i plan to save the item in specific array in the arraylist and here is the error i got
java.lang.RuntimeException: Unable to start activity ComponentInfo{com.example.java/com.example.java.MainActivity3}: java.lang.ArrayIndexOutOfBoundsException: length=1; index=1
Help Google Play Apps will NOT Update!
Did you also clear all data from Google Play Services?
I know you say that was done for Google Play Store, but the two separate apps work together.
Hi, this has been resolved a while ago. After a couple of Google Play manual updates it started updating on it's own and updating apps normally. I'm sorry, I should have marked this as resolved. I'll do it now. Thanks for getting back.
Help Anyone know the OTG connected flash drive max capacity for the S8+?
Android only supports FAT32 and exFAT for external USB media so the issue doesn't sound like it necessarily has anything to do with that Sandisk flash drive itself but there's a good chance whatever OTG adapter is the actual problem. If that is the case, it makes no difference what USB storage media you try, if the OTG adapter/cable isn't compatible with your S8, nothing can be detected and mounted.
Do other USB devices connect to your S8 through this OTG adapter/cable and it's just this Sandisk drive that's a problem? That would indicate the problem is with the Sandisk drive and your phone. If you cannot get anything to connect to your S8, using that OTG adapter/cable, that would indicate that it is the problem.
What OTG cable/adapter do you have?
Note10 Hacked
Yeah no idea how exactly it was infected or whatever. It would have to be some sort of zero day. Thing is I am sure that this is going on just cannot explain it as unlikely as I know as that sounds. There has a been a lot of those discovered lately
You actually said earlier that you had installed several security apps and a VPN before it happened.
Uninstall them all, wipe the cache partition and see if it stops.
One of them is possibly sending false popups that you have been hacked to trick you.
No need at all for flashing new firmware at this stage. Step back from the dynamite folks, we don't know where the rat is yet.
Also, If you go into Sttings/About/Software Information:
What are the One UI and Android versions listed?
Bode.
add delay between videos
im looking for a way to play videos but add a delay between videos, so during the delay there won't be anything on the screen at all, then when the video starts back up again, the video will be displayed again
the reason is because im making reaction videos, and a lot of videos will get blocked if you show too much of the video, especially for reacting to tv shows like the walking dead, so that's plan only show 10 seconds at a time, then have a black screen from a video that i made with black pictures, then i would use the pop up view for the video player, if i could get this to work, it would save a tremendous amount of time editing, because right now i have to add lots of pictures over and over again throughout the entire video, and for tv shows it's a very long process
Also it doesn't necessarily need to be a video player to accomplish this, it could also be done with a video editor, although so far the ones i tried, kinemaster and video show, once you cut out a section the 2 remaining sections fits together instead of staying apart, and with kinemaster although you can make clips transparent you can't make the parant clip transparent just the overlays, any ideas to accomplish this affect would be awesome, and i Will be forever grateful for any ideas thanks
Filter
