Is RPG worth the time?
I am just a beginner and never tried any RPG on PC, played 2 RPG games on my phone. But they didn't look exciting enough, so I thought maybe any reference will be better. And I don't have any preference, just wanted to dive in.
there so many great rpg on pc. can't really say that for mobile devices.
skyrim is my favorite of all time. i hear witcher 3 is really good as well. you can also go more sci-fi in the fallout series as well. start with fallout 2 or 3. and i can't forget to mention horizon zero dawn........its soooo gooooood. you get to fight robotic dinosaurs!!!!!!! enough said LOL.
if you like survival games, i would recommend subautica and subnautica below zero.
Samsung galaxy A22 shutdown on screen timeout
Hi All,
My new Samsung galaxy a22 shuts down whenever the screen times out. Any way I can stop this glitch?
are you sure it is powered off and not just asleep? if this is indeed happening, then i would first put the phone in safe mode to see if the issue still happens. safe mode prevents 3rd party apps from running. this will determine if this is an app issue or not.
https://www.hardreset.info/devices/samsung/samsung-galaxy-a22-5g/safe-mode/
your next option would be to do a factory reset. this will determine if this is a software issue or not. keep in mind this will delete data, so backup accordingly. and do this from within your phone' settings. you can do a hard reset, but that will trip frp(factory reset protection) and you will need to know your google acct info or it will not let you proceed any further.
and if it still continues then you might want to look at warranty replacement options.
Backup query needs explanation !!
The logic of the Google backup is that the apps can be re-downloaded so it's the data backup that's important. But I don't know why it doesn't back everything up (at least for me) - to be honest for many years I rooted all of my devices so it didn't matter to me whether it worked or not, and after one poor experience with it I never bothered with it again, and hence never learned whether there are any tweaks with it.
I've known others swear that it's great, but I suspect that it just worked for them and so they won't have ideas. But we can hope.
Changing app install location
Well bear in mind that any bloatware they have installed has probably been installed to /system, which means you can't move it even if your device has those features. The best thing to do with that stuff is uninstall any updates, clear the app's storage and disable to app (so it can't update or store new data, and doesn't appear in the app drawer to annoy you).
Deleting old texts
Yes, this is a common feature on many SMS apps, especially third-party apps, and if the built-in app doesn't do what you want you should not settle for it (there's nothing special about a manufacturer's SMS app).
I don't use this feature, but as examples Textra (my current default SMS app) lets you set a maximum number of messages to keep (per conversation, separate limits for SMS and MMS), while QKSMS (which I used recently) lets you auto-delete messages above a certain age. The stock app on my phone (Google's Messages app) does not have this feature, but having few options is typical for Google apps (one reason I replace almost all of them).
Android USUSB not recognised - settings completely disappeared
Good day,
Yesterday I connected my Huawei P30 Pro with Android version 10 to my PC with Windows 10 via USB as usual. The computer did not recognise the device as a USB device. So I tried to change some settings in the device. When I then switched off the developer mode, I was no longer able to select any USB-related settings in the settings. The entries still appeared in the menu and in the menu-internal search, but could no longer be selected.
I then tried to solve the problem by resetting the network settings. Now all the USB-related entries no longer even appear in the system settings. When I plug it in, however, the "USB usage" dialogue appears and when I select "Enter MIDI", the computer recognises the device. However, data transfer is not possible in any of the modes.
I would like to avoid resetting the device completely, is there another possibility, maybe reinstalling the USB driver manually or similar?
Many thanks in advance for your help!
Help Blue dots/stains on camera
I have same problem I take picture at night time and it will alway have the blue pixel on screen. I have try to zoom in to the picture for me to see what is the problem but always not obvious what problem is. Please indicate with a reply what I should do so that this problem can be fix ASAP as possibly. This is very important that you reply with fix so that all next Samsung phones will be best than the old Samsung phones. Tahnks!
Filter
