Help Android. Incallui
Ok I am going to try my best from my research and understanding is that Samsung has updated their system to system UI and that is indeed what we are seeing,(com.Samsung.android.incallui) and (Used com.Samsung.android.messaging) and (Used com.samsung.android.dialer). Ok so I was told that anytime you touch the dial pad these will register but whats makes more sense is when we dial and call and then engage in it registers as above, then when you are using text messaging the messaging one shows up... Now for the not showing up on your carrier cell phone bill I have Sprint/Tmobile and nope it doesn't show up there and that I do believe is because the person is using a 3rd party phone and texting app that the only other explanation. So the lady above being concerned about her husband maybe should be. I have read many say oh its nothing just the nuts and bolts of out dialer paid dont worry about it. HaHA this is new to me and I know my guy talks to his ex's and others like a sneaky snake behind my back, So I do believe its some hidden agenda going on with a third-party app. APk is what my sneaky boyfriends has! I could have a little wrong but not too much. any knowledge to enlighten us would be great!! Thank you. I hope this may help someone. until we hear something official.
Gallery Not Saving Original Image
I found that when I edit the image, usually just cropping, there is a button at the top.
The button is Save. That's the one that overwrites.````````
Butt I found a command in the pull down menu (the 3 dots) has an option to 'Save copy'
which doesn't overwrite.
Since I saw the 'Save' command at the top I never bothered to ;look elsewhere.
I thing they should be switched.
Most stock apps really suck.
Try the ones I posted links to.
They are both great.
Screen problem Galaxy A70.
definitely hardware damage. i damaged my note 4's screen by hitting the phone's sides while my phone was in a gym bag when it fell from my gym's locker after working out. it did not crack the screen, but the jolt definitely broke something on the inside. luckily i had insurance on the phone and was able to get a replacement with out having to dish out large sums of money.
i never keep my phone in a bag from that day forward. it is always with me.
I Hate Google
Ok, so an epilogue to this.
I did figure out a way to disable lots more Google poop on this pathetic little device.
I do still get the warning that the device is out of date, bevging me to 'update' it, but now it is just a notification and there is no more countdown and forcing of updates.
No clue as to what app(s) are responsible, but I am glad to have it to this point.
I can now restart the device and not have a bunch of Poogle shoved down my throat.
My guess is that if I removed my Poogle account altogether that the issue would end altogether.
If and when I get all my contacts as device instead of Poogle, then I will do just that.
As it is now, all my contacts disappear if I remove the account.
I have tried to export them en mass and then import them after the account is gone, to no avail.
Help My device is joy tab 2 tablet.
I moved your post into the lounge area so we can get more eyes on it.
Could you be a little more specific with both your problem and device? When you say you are having trouble verifying the tablet, are you trying to root it? Flash firmware? Update? Do you know what firmware is already installed? Do you have a model number for the tablet?
This would be helpful for everyone to understand what's going on.
Thanks and welcome to the forums. :)
Filter
