Help Dodgee N20 sharing internet with pc slow
I guess it also may be related to the LTE/4G and 3G data frequency bands the phone is capable of receiving, and those of your carrier or network.
It's not a bad phone, despite your Freudian slip if you are in the UK (It's a Doogee N20) but there were better phones even for that money or less. You were possibly suckered by Amazon or other site in a quick search.
Depending on the world region you bought it, you can compare the 4G bands on the phone with those your carrier uses.A quick browse yesterday seemed to show a limited number of bands on that phone, but I may be wrong.
I only use my phone, and a Mifi dongle with a sim card, to have home wifi. You say it's been OK previously for you, and where I am in the UK most unlimited data plans allow unlimited tethering as well.
activity restart due to Configuration Change
My activity is getting restarted, to avoid this I have added the possible configuration changes in my Android manifest still activity getting restarted. The android manifest as below
<activity android:configChanges="density|touchscreen|mcc|mnc|orientation|uiMode|screenLayout|screenSize|smallestScreenSize|layoutDirection|locale|fontScale|keyboard|keyboardHidden|navigation" android:name="org.app.Activity" android:label="MyApp" android:screenOrientation="landscape" android:launchMode="singleTop" android:theme="@android:style/Theme.Holo.NoActionBar.Fullscreen">
I have get the configuration at runtime and logged in Log file, The older configuration as follows
{1.0 ?mcc?mnc [en_IN] ldltr sw800dp w1280dp h728dp 160dpi xlrg land finger qwerty/v/v -nav/h winConfig={ mBounds=Rect(0, 0 - 1280, 800) mAppBounds=Rect(0, 0 - 1280, 752) mWindowingMode=fullscreen mDisplayWindowingMode=fullscreen mActivityType=standard mAlwaysOnTop=undefined mRotation=ROTATION_90} s.5}
And the changed configuration as below
{1.0 ?mcc?mnc [en_IN] ldltr sw800dp w1280dp h728dp 160dpi xlrg land finger qwerty/v/v dpad/v winConfig={ mBounds=Rect(0, 0 - 1280, 800) mAppBounds=Rect(0, 0 - 1280, 752) mWindowingMode=fullscreen mDisplayWindowingMode=fullscreen mActivityType=standard mAlwaysOnTop=undefined mRotation=ROTATION_90} s.7}
Please could you tell me what is this s.5 to s.7 change stands for?
Permanently Disable Weather Alerts?
and double check to see if you have allowed notifications from your browser. some websites will send you notifications to your phone.
Well, I may have found it. I don't mind weather alerts coming in; it's that horribly screechy alert sound I object to. I found the text of the weather alert in my text messages which indicates to me it was a text. I didn't know text messages would do that horrible sound that would wake the dead.
I had TMobile disable text messaging on my line for ten years or more and recently changed my rate plan and I guess they turned texting back on when they did it. I also found about fifty other BS messages in there, too.
Just another reason to again to disable texting. I think I'll call TMobile and tell them again to disable texting on my line.
Connecting phone with an audio interface (focusrite)
Regarding the audio interface issue, your Galaxy J7 (2016) apparently has a microUSB port and supports OTG so that port does allow for charging and data transfer, but it might not necessarily also support audio in/audio out too. If it was a USB Type-C port than yes, that has additional pins and with more functionality than microUSB.
https://www.gsmarena.com/samsung_galaxy_j7_(2016)-7870.php
As for data transfers, try connecting your phone directly to the other device, bypassing that USB hub.
OTG
https://en.wikipedia.org/wiki/USB_On-The-Go
microUSB
https://en.wikipedia.org/wiki/USB_hardware#Micro_connectors
Type-C (...which your phone does not have)
https://en.wikipedia.org/wiki/USB-C
Help Phone display black after booting, the display works when booting
Back up anything important and try a factory reset.
If you have the option in recovery mode, try wiping the system cache (just the cache, not cache+data, not factory reset). That was removed from most phones a while ago, but I'm hoping that a phone I've never heard of might still have a useful legacy feature like that. There's a small chance that that might fix it, in which case you are spared a reset. But otherwise my best guess is that you've got some corrupt data somewhere that's messing up the display drivers, and I doubt I'd be able to track down precisely what (and if it's system data I might not be able to remove it anyway without root), in which case a reset will be needed.
The worst case is that the actual system software has been corrupted, in which case a reset won't help either (in that case either a reflash would be needed or, if the storage itself is damaged, there would be nothing you could do). But I think there's a good chance of a reset fixing it. From what you describe it's clearly a problem with the android system rather than the hardware, since the splash screen and boot animation work (which all come up before the Android system takes over).
Filter
