Solid Explorer cannot access local ftp
- Apps & Games
- 6 Replies
What about using a LAN connection with Solid explorer?
Pull down your quick settings menu.
Find the little pencil, the 'edit' icon.
Tap that and then scroll all the way down to find the quick setting tiles that are not active.
Perhaps the USB quick setting tile is there, and can then be moved up into the quick setting tiles that are active.
"The emulator process for AVD <AVD-name> was killed"
C:\Users\Nuno\AppData\Local\Android\Sdk\emulator>emulator.exe -avd Nexus_6_API_30
emulator: Android emulator version 30.6.5.0 (build_id 7324830) (CL:N/A)
handleCpuAcceleration: feature check for hvf
added library vulkan-1.dll
Failed to open /qemu.conf, err: 2
HAX is working and emulator runs in fast virt mode.
emulator: INFO: GrpcServices.cpp:315: Started GRPC server at 127.0.0.1:8554, security: Local
emulator: INFO: EmulatorAdvertisement.cpp:93: Advertising in: C:\Users\Nuno\AppData\Local\Temp\avd\running\pid_11172.ini
Failed to sync vcpu reg
C:\Users\Nuno\AppData\Local\Android\Sdk\emulator\qemu\windows-x86_64\qemu-system-x86_64.exe: error while loading state for instance 0x0 of device 'goldfish_pipe'
deleteSnapshot: for default_boot
VCPU shutdown request
emulator: Saving state on exit with session uptime 25 ms
Thank you my friendIt looks interesting! Will try today!
My experience was quite different. for a start I had no problem with carriers. I just swapped my SIM from my Huawei Mate10, I'd been using for over three years, into the new Note20 Ultra, and up it came showing China Unicom 5G service.And that's the same SIM I've actually been using for six years now in various phones. That was originally micro size, and I trimmed it down to nano size for one of the Oppo phones I had.
As for the camera, I don't think it sticks out too much, and it seems to be well protected by the silicone case the local Samsung store gave me with the phone. I also used Smart Switch to transfer apps and data from the Huawei to the Samsung, and the only other things I had to do was to sign into various accounts again with a new device, like WeChat, AliPay, etc.
I'm thinking Samsung is just sending out generic notifications or China is up to something shady
And since I posted this we've had CAD-based renders of the Pixel 6 range which show that they are planning to release 2 phablets this year. So that's a Pixel out of the picture for me next time (materials aren't specified, but if the glossy look of the renders is based on real information it might be back to the glass sandwich too - which moronic bloggers will call "premium").I do agree that the market is frankly rather crap, though mainly for different reasons: in my case it's particularly this obsession with oversized phones to the exclusion of all else. In fact I'm at severe risk of having a choice of Sony or Apple if I need a replacement in the near future, and absurdly Apple are the more reasonably-priced of the two! And yes, phones are increasingly ridiculously priced for what are marketed as short-lived devices - and when you consider the resources that go into making one of these things the idea that you might replace it after 1-2 years, as the industry pushes people to do, is pretty much criminal (the main reason I've never bought into this "you are due an upgrade" culture the carriers work to encourage).
TBH the two "innovations" I'd like most are better battery technology and the death of the "glass sandwich" design (the fact that none of the 2020 Pixels was a glass sandwich was one thing that Google got right last year). And "better battery technology" means higher charge capacity and longer battery lifetime, not gimmicky high-power charging (which is part of the "disposable" culture problem IMO).
Does anyone know of a way of registering the google account in the UK? Why does the Hub work on a browser on Windows computers?
I'm trying to simplify my life, and not have so many different devices. I'm also an documentary filmmaker, and I know the Fold 2 has a good camera.
However, I'm wondering how it do rendering video footage (1920, not 4k). I know a lot of laptops aren't made for rendering an entire feature film, so I'm guessing the Fold may struggle with that.
However, I'm curious if anyone has tried rendering a feature film using the Fold and android video editing apps, and if so, how did it go? What were the pros and cons of doing so?
Thank you for any feedback.
Hey there, Masterchief87, were you ever able to figure this out? I have been trying to update mine and I got to the same point you did. Hate to bump an old thread, but this is the last lead I have found to root this thing / install twrpUnlocking the bootloader is the easy part. You just type 'fastboot oem unlock' and that's it. The complicated part is flashing a custom recovery because apparently the version of fastboot that comes on the T-Mobile G6 doesn't support the 'fastboot flash ______ _______' command. Installing a custom recovery involves flashing the laf partition (download mode) from the h918 then booting fwul Linux from a USB stick and running a script that flashes your recovery to the laf partition, which finally allows you to root, flash roms, and install your custom recovery to the recovery partition. I got as far as unlocking the bootloader and flashing the laf partition from the h918 but the second step that requires using fwul Linux to install the recovery didn't work, for reasons which I don't yet understand. The phone still works fine but for the time being I've lost the ability to use download mode to flash a stock kdz firmware.
No i have not but im will post and follow the XDA post you gave me. Thanks
<layout>
<androidx.drawerlayout.widget.DrawerLayout xmlns:android="http://schemas.android.com/apk/res/android"
xmlns:app="http://schemas.android.com/apk/res-auto"
xmlns:tools="http://schemas.android.com/tools"
android:id="@+id/drawerLayout2"
android:layout_height="match_parent"
android:background="@color/white"
android:padding="3dp">
<androidx.constraintlayout.widget.ConstraintLayout
android:layout_height="wrap_content"
android:background="#FFFFFF"
android:padding="2dp">
Textviews, buttons, etc... removed so this would fit.
</androidx.constraintlayout.widget.ConstraintLayout>
<com.google.android.material.navigation.NavigationView
android:id="@+id/navigationView2"
android:layout_width="wrap_content"
android:layout_gravity="start"
android:fitsSystemWindows="true"
app:headerLayout="@layout/nav_header_main" >
</com.google.android.material.navigation.NavigationView>
</androidx.drawerlayout.widget.DrawerLayout>
</layout>
That doesn't seem right - the newest version 313.0.0.15.119 from Google Play was updated 3 days ago, it's not old. I'd be suspicious of the higher version numbers.
If Facebook changed the name of Messenger to Work Chat there would be news articles about it, but I don't see any.
Also, post moved to correct forum![]()
