Galaxy Tab S7 FPS issue
- By onthevirg
- Smartphones
- 5 Replies
Well out of curiosity I tried to run the game with the tablet plugged in and it doesn't seem to lag as bad. Leads me to believe it's hardware related.
phone cooler? what is that? is it an ad as @mikedt suggested? can you post a screenshot of it?
That sounds like what I used to with Commodore 64 and Amiga games back in the day, using Action Replay or Game Genie cartridges, where I could enter certain hex codes into a game and it would give me infinite lives, or infinite ammo, or make me indestructible, etc. But these cheat cartridges were hardware devices plugged into the computer, and the hex codes were all documented. However I'm quite certain there's no cheat cartridges made for Android,
Thing is, you might have a hex editor app and the game files, but you'd need to find the exact bytes you have to edit to achieve your desired cheat in the game. Of course I don't know what game you want to hex edit, but it may have countermeasures against hacking/tampering, like running CRC checks.
I believe that my phone was sold in the UK and I have an EE sim but I don't believe it was obtained from EE originaly.I have a .exe that is supposed to work, but as I said I can't actually get into download mode to use it. I had a look at the internals and I don't see any signs of heat or water damage, so I believe the NAND has just died. Not sure if it was planned obsolescence orjust dropping it one too many times, but I think I'm going to try extract 2FA codes from Google (I can't log into Discord without them) and I'm just going to buy a new screen and frame for my broken u11 to fix that. Thank you for all of the help!
What no replies? All these genius with an opinion and no answer. Why don't you guys tell me how normal this is.
class MainActivity : AppCompatActivity() {
override fun onCreate(savedInstanceState: Bundle?) {
super.onCreate(savedInstanceState)
setContentView(R.layout.activity_main)
firstText.text = "Welcome humans"
Wow! Love the galaxy s21 ultra 5g and it's specs.
Any ideas where I can get a great deal without signing on to a new carrier? I am on simple metro pcs.
Thanks!
PM
ok then you are screwed.....those things are locked down extremely tight.The device is a Securus JP6s. I’ve recently left being incarcerated and am trying to unlock my tablet without having to send it into the manufacture and paying for it.
Busy or dead. Doesn't matter.
I considered that too, doesn't seem to be the case.
I just noticed yesterday that the opening of an app doesn't matter, it will disconnect app or no. I just didn't notice the d/c until I opened an app.
You know I'm not sure. Possibly. I hadn't considered that. I'll have to think about that one. I don't make note every time my phone updates, ya know?
Wifi seems solid. 5/5 bars. Plus they have a Wifi booster.
