Sd card started overheating inside the phone
Any microSD card is just inert storage media. There's no spinning disk involved that requires a motor and power for that motor, nor is there even any mechanism that will generate its own heat source. The heat you felt was mostly just transferred from some component in the phone itself, up through that card. Blaming the card for that heat issue is misleading you from looking into the actual problem and its source.
I see... Interesting point.
Trying to find out whats been going on when Husband uses my phone.
Oh my God it is such a relief to see this thread I have been driving myself crazy trying to figure out what my boyfriend of 4 years is up to what he's doing to my phone and why but I don't think it's him trying to spy my phone I think he's trying to keep me from seeing what he's truly doing because we both have access to each other's accounts. I have a Motorola 5G one Ace with metro PCs and I think that it's using ADB to install things on my phone and I have a shared emulated storage. I believe my phone is linked with the laptop. It also has midi server and I don't think that most phones come with that if anyone can help me out there. I try to open web pages and I get 403 error or 404 error or things simply just won't load my Bluetooth toggles on and off by itself. Now my phone's simply won't send messages that's the only thing. I can tell the difference from when I first bought the phone which was March 20th of this year till now the difference in how it runs the picture quality everything. It's a big difference. I don't know if this will help explain this to anyone that can help me figure out what it is he's doing and how to get it off my phone because if I factory reset it it looks like it resets it but but it doesn't really reset it I've tried doing a hard reset it won't pop up for anything I just want to know how to get this off my phone and what it is he's up to so I can show him proof and he can't say that I done it or he doesn't know where it came from if anyone can help please do
Motion warning freezes screen
When I try to use Android Auto I get this annoying text window overlay saying the some functions are not available while the vehicle is in motion. This seems to impede most functionality. Can this be3 disabled? I'm on Android 11.
I don't use Android Auto, but FWIW I've only ever seen a warning similar to that when I was trying to play Harry Potter: Wizards Unite in a speeding taxi on the Beiyuan Expressway in Jinan.
EDIT:
For that, there was a "I'm not driving" box, which i checked.
Cleaning com.android.vending
I have an old device out of space. I have uninstalled as many applications as I could. I have migrated every application possible to the SD Card. I have deleted every discretionary file (e.g., podcast MP3, etc). What would you recommend as a good strategy to get back space? No doubt there are tons of logfiles and cached files in binary formats but I do not dare delete those things if I do not know the application that created them and what it needs to find to work.
So you think everything in the data folder under vending folder can be deleted safely?
yes, you can delete it, but do not be surprised if android rewrites the folder later on. that is what temporary cache files and folders are for.
what phone do you have? how much room to do you have?
Help Galaxy Y - synchronize CalDav appointments
Hi and thank you for your quick answer :)
Before posting I asked to myself if the flashed ROM was really a Marshmallow version. I tried from the Linux bash shell with ADB
Code:
user@host:~$ adb shell getprop ro.build.version.sdk
10
So I suppose that the real version is in fact 10 GINGERBREAD MR1 (the same that the ROM Stock) and not 23 like I believed.
I do not know the right way to ensure me the REAL flashed version. Could you explain me how to get it ?
If this is not a Marshmallow ROM, where can I find a REAL Marshmallow ROM ?
there is no such thing, unfortunately.....from what i understand is that the base of the rom is whatever the highest android update is for your phone. the dev then adds in features of whatever android version the dev wants to use. the problem is that higher android versions that is not made for your phone, could have potential of not running smoothly and become unstable.
the rom you flashed is a marshmellow themed rom......just an fyi
.....that is my understanding as far as custom roms go.
so like i said find an older apk of davdroid and you should be fine.
you will not find an actual android 6 custom rom.
Listview updating item issues
I've solved both issues. Actually found that the String value that I was using to select my icon in my arrayadapter was appearantly getting a string with an extra space in it from the return data. This caused my ImgID variable that I was using to set the image to default to ic_launcher (which I set as default icon for testing). I changed the cat == "VALUE" to a cat.contains("VALUE") to avoid this issue.
Java:
        int imgID = R.drawable.ic_launcher_background;
        String cat = data.getCategory().toUpperCase();
        if (cat.contains ("MAINTENANCE")) {
            imgID = R.drawable.icon_engine;
        } else if (cat.contains ("DOCUMENT")) {
            imgID = R.drawable.icon_docs;
        } else if (cat.contains ("FUEL")) {
            imgID = R.drawable.icon_fuel;
        } else if (cat.contains ("DRIVING")) {
            imgID = R.drawable.icon_steeringwheel;
        } else if (cat.contains ("BUSINESS")) {
            imgID = R.drawable.icon_taxi;
As for updating the Listview Item I stripped most of my code out of the above code and simply created a new itemData using the returned data.
Java:
    @Override
    protected void onActivityResult(int requestCode, int resultCode, Intent data) {
        super.onActivityResult(requestCode, resultCode, data);
        if (requestCode == 501 && resultCode == RESULT_OK) {
            DecimalFormat f = new DecimalFormat("000,000");
            int locid = data.getIntExtra("locationid", 1);
            int id = data.getIntExtra("id", -1);
            int pos = data.getIntExtra("position", -1);
            int mil = data.getIntExtra("mileage", 0);
            double cos = data.getDoubleExtra("cost", 0);
            String typ = data.getStringExtra("type");
            String tit = data.getStringExtra("title");
            String des = data.getStringExtra("description");
            String dat = data.getStringExtra("date");
            LocalDateTime lt = convert.DateTimeFromString(dat);
            items[ItemPosition] = new itemData(id, des, mil, cos, "", typ, 1, 1, lt);
            mAdapter.notifyDataSetChanged();
My ItemPosition variable stores the value of the item clicked on in the listview onclicklistener so that when a result is returned I can get the actual item that was clicked to edit. mAdapter.notifyDataSetChanged() does update the entire view after the original data has been modified. My issues were self-inflicted with the string comparison and not properly updating the original data. Live and learn, right?
You should compare String using stringA.equals(stringB) instead of use stringA.contains(stringB).
At the time I begin learn Android, I got very much issues too.
Filter
