Does anybody know what this notification icon is?
- By cprpro
- VIP Lounge
- 3 Replies
Thank youThat is google messenger. A text message
DamanaIn Android 10 (MIUI12), there is a switch to prevent apps from being manually killed from inside the switcher panel.
When clicking kill all (X) it kills all apps but the ones protected by the switch.
I did protect one app already once but are unable to find the relating setting page again :-(
Extensive googling didn't help.
Anyone here with a clue?
Thanks in advance!
package com.logista.test.ui.home
import android.os.Bundle
import android.view.LayoutInflater
import android.view.View
import android.view.ViewGroup
import android.webkit.WebResourceRequest
import android.webkit.WebView
import android.webkit.WebViewClient
import android.app.DownloadManager
import androidx.fragment.app.Fragment
import androidx.lifecycle.ViewModelProvider
import com.logista.test.R
class HomeFragment : Fragment() {
private lateinit var homeViewModel: HomeViewModel
override fun onCreateView(
inflater: LayoutInflater,
container: ViewGroup?,
savedInstanceState: Bundle?
): View? {
homeViewModel =
ViewModelProvider(this).get(HomeViewModel::class.java)
val root = inflater.inflate(R.layout.fragment_home, container, false)
val myWebView: WebView = root.findViewById(R.id.webview)
myWebView.webViewClient = WebViewClient()
myWebView.settings.javaScriptEnabled = true
myWebView.loadUrl("https://www.example.org/")
return root
// Set web view download listener
web_view.setDownloadListener(DownloadListener {
url,
userAgent,
contentDescription,
mimetype,
contentLength ->
// Initialize download request
val request = DownloadManager.Request(Uri.parse(url))
// Get the cookie
val cookies = CookieManager.getInstance().getCookie(url)
// Add the download request header
request.addRequestHeader("Cookie",cookies)
request.addRequestHeader("User-Agent",userAgent)
// Set download request description
request.setDescription("Downloading requested file....")
// Set download request mime tytpe
request.setMimeType(mimetype)
// Allow scanning
request.allowScanningByMediaScanner()
// Download request notification setting
request.setNotificationVisibility(
DownloadManager.Request.VISIBILITY_VISIBLE_NOTIFY_COMPLETED)
// Guess the file name
val fileName = URLUtil.guessFileName(url, contentDescription, mimetype)
// Set a destination storage for downloaded file
request.setDestinationInExternalPublicDir(Environment.DIRECTORY_DOWNLOADS, fileName)
// Set request title
request.setTitle(URLUtil.guessFileName(url, contentDescription, mimetype));
// DownloadManager request more settings
request.setAllowedOverMetered(true)
request.setAllowedOverRoaming(false)
if (Build.VERSION.SDK_INT >= Build.VERSION_CODES.N) {
request.setRequiresCharging(false)
request.setRequiresDeviceIdle(false)
request.setVisibleInDownloadsUi(true)
// Get the system download service
val dManager = getSystemService(Context.DOWNLOAD_SERVICE) as DownloadManager
// Finally, request the download to system download service
dManager.enqueue(request)
// Load button click listener
button_load.setOnClickListener{
// Load url in a web view
web_view.loadUrl(url)
You may need to do a factory reset to fix the issue
