Help How to unlock a Password lock Sony Xperia L C2105?
I 've forgotten my password to unlock my phone, I've try to put the phone to recovery mode but it didn't work as the internet says. Then I've try Sony Companion but it don't support on my computer (running Windows 8.1 32 bit). So is there any way to unlock my phone?
the only way is to do a hard reset.
https://www.hard-reset.org/factory-...off the SONY XPERIA,C2104/C2105/S36h) TAOSHAN
Accessories lapdock // monitor+keyboard
My phone does have usb-otg support as well as smart-view over wifi for connecting to displays that support smart-view. but how do I find out what's the maximum resolution that can be output by my phone?
That basically means a smart-view enabled Samsung TV, connected to your WiFi. AFAIK smart-view is proprietary to Samsung devices only. I guess the maximum resolution will be whatever the TV is capable of, but you should at least get 1080p out of it.
Video latency might be an issue though if you're intended to uses it for PC computing type purposes rather than just watching videos through smart-view.
Accessories [Free] [App] QR Code Scan (Android App)
Good News!
We are happy to announce that we have developed new QR Code Scan (application to the Android platform. Now you can use the same application on Android Platform.
QR Code Scan (Android App) is the most updated application.
QR Code Scan application allows you to generate unlimited QR codes..
Download Details:
Application Name: QR Code Scan
Play Store Link:Download
URL: https://play.google.com/store/apps/details?id=com.wmdev.tools.qrcodescan
You can also rate our QR Code Scan application in the Google Play Store.
AUC8 BIG update for Global S21 series, camera & April security patch
Samsung are certainly putting their back into pushing out this 1.1GB AUC8 firmware with the April Android Security patch.
In under 6 days they have released no fewer than 100 updates for countries and carriers across the globe, from Afghanistan to Vietnam, for their Galaxy S21 Exynos global series.
Phone manufacturers are often criticised for the tardiness of their updates but Samsung are excelling themselves on this roll out.
Need Help With Input Jack
Actually you can. I've done it many times as this photo will show. It is a dual purpose jack and many phones have them but that information is not usually in the manuals... but a quick search on Google/YouTube will show it. For this shot I was using a Movo VXR10 microphone.
The issue I have is that when you do use an external microphone, the speaker is deactivated; on the G7 at least. I suspect the reason is the phone thinks you're using a headset with a microphone, even though it shows an external microphone option in camera settings. That makes no sense, but anyway. I would like to have the speaker functional as needed when I have a microphone plugged in.
OK that's something I've never used before. But I have used USB wireless mics with Android devices,
similar to this one... https://www.amazon.com/Microphone-A...ywords=usb+wireless+mic&qid=1617432192&sr=8-7
That I also use with Macbooks.
Filter
