Icon
What app or web site is this icon? A butterfly
a screen shot of it would help as @Hadron suggested.
so we get this question almost every day. the problem is that most of these types of questions go unanswered. mainly because they are millions upon millions of apps available....each with their own icons. so unless it is an app like facebook or youtube, it might prove harder to find someone who will recognize it.....now first we need a picture of the icon because there probably is thousands of apps that will use some sort of butterfly as their icon.
the easiest way is to look in the phone or device where this notification is at....but my spidey sense tells me that the phone is un-accessible because it belongs to someone else. you could just ask the person.....or not.
anyways post a screenshot and your chances will improve in someone recognizing it.
Help My generic Smart TV won't install media players
Thank you all for your help. It is well appreciated. @Dennydet sorry but yes, media players do control hue, contrast etc. (VLC, GOG and others do). @ocnrze that may be true with most cases but not all. Remember that what is inside a Sony, Samsung etc are all parts made elsewhere (Aren't most screens made by Samsung)? @mikedt The reason why I did not buy a stick or other things (or why I bought a generic TV) is because I do not know how long I will stay here. No use spending money if I am going to leave after 6 months or a year and then have to give it away or sell for much cheaper. The T95 seems like a good idea if, and only if, the power is 120v-240v. I will look into it. (and if possible get an English remote ;-)
P.S. BTW my TV already has Chrome, YouTube, etc. but I do not use my TV for anything except view videos from a HD. I do not stream, do not use the browser etc. I may at some point perhaps stream sports matches; hockey, football (soccer), Olympics. Thanks again ye all :)
Yeh, the T95 box comes with a universal voltage power brick. and it's all in English. Although there are couple of Chinese apps pre-installed, like CCTV's app, but those can be deleted. Once a reliable VPN(like Express or Astrill) is installed and connected, Google Play, YouTube etc. all work fine in China. The T95 box itself will work pretty much anywhere in the world, so you can take it with you when and if you leave China.
I use Kodi for playing videos from USB hard-drives via the T95 box, and that's got brightness, contrast, colour, and hue adjustments in it for videos.
Glass screen protector for Poblano HotPepper VLE5
Guessing you've tossed the pkging, any idea who the manufacturer is? or did you mean basically any iPhone x?
It is just a glass screen protector, costs about $5 at Big Lots.
As it is made to fit the iphone X, I would assume that any such screen protector made to fit the iphone X would fit.
It is not a 'perfect fit', but it is 'close enough for government work', lol.
How can I get form data from a header in Android WebView?
Hi,
I have to use Android Webview in my project. Inside of the Webview I have to use a form. After the user fills and sends the form, Form redirects to 2 or 3 different links and in the final, it returns to one link with the result. Result comes from Header Form Data. I have to read form data and check the result. With javascript injection, I can reach the response header(content-type, content-length etc.) but I could not read the Form Data from Header.
How can I get the Form Data from a Webview?
Thank you.
My S7 has stopped downloading email!
Thank you for your reply. Looks like they have got themselves into a bit of a tangle.
The first thing to do is to open up the Play Store and make sure that you have the most recent update of Android System Webview.
When I try to do this I just get an error message saying that "authentication is required. You need to sign in to your Google Account." ...but I am signed in.
Then be sure that G-Mail is not in your recent apps, and restart the app from your appdrawer, or the icon on your homescreen if you do it that way.
Trying this, I get "Getting your messages." which just keeps churning on and doesn't stop.
You can also go into your device settings, find Accounts, and verify the sync there.
Yup... sync is turned on.
Stil not working?
Then go through the settings within the G-Mail app.
Somewhere in there is the controls for how much e-mail is brought in when you open the app.
I changed it from 30 days to 20 days to see if would undo the log-jam.
Magic! That worked! My email was downloaded. I'll keep this one to try if it all goes pear-shaped in the future.
Thanks again.
Help How to remove previous users?
I don't have that and neither does he anymore. He moved to an apple device and only uses iCloud stuff.
Moving to Apple doesn't matter as long as he still knows the Google credentials.
Otherwise, good luck: lockscreens will generally have some protection to make brute forcing unviable, like time-outs after a small number of incorrect entries (or, though this is mostly older devices, factory resetting after some number of incorrect attempts, at which point you need the Google login anyway).
Filter
