Make for android9 vivoy19
- By Hadron
- Apps & Games
- 4 Replies
Plus I'm pretty sure KingRoot doesn't work with Android 9 anyway, so it's a waste of time wishing for it.
agreedI’ll use that next time .... the ‘backup’ apps built in to OS should be removed, useless.
public void initStreamerInfo() {
ImageView streamerAvatar= findViewById(R.id.livestreamingHeader_streamerImage);
TextView streamerName = findViewById(R.id.livestreamingHeader_name);
TextView streamerAge = findViewById(R.id.livestreamingHeader_age);
followingImg = findViewById(R.id.livestreamingHeader_followedStreamer);
if (streamerAvatar==null){
Log.d("statusofimgvw","kuch nhi ho sakta");
else {
Log.d("statusofimgvw","Not null");
User puser=mLiveStreamObject.getAuthor();
Log.d("checkingvaluel",puser.getProfilePhotos().get(puser.getAvatarPhotoPosition()).getUrl());
Log.d("checkingvaluel",puser.getColFirstName());
Log.d("checkingvaluel"," "+mLiveStreamObject.getAuthor().getProfilePhotos());
QuickHelp.getAvatars(mLiveStreamObject.getAuthor(), streamerAvatar);
streamerName.setText(String.format("%s, ", mLiveStreamObject.getAuthor().getColFirstName()));
if (mLiveStreamObject.getAuthor().getBirthDate() != null){
streamerAge.setText(String.valueOf(QuickHelp.getAgeFromDate(mLiveStreamObject.getAuthor().getBirthDate())));
setTimer(mLiveStreamObject.getStartedAt());
FollowModel.queryFollowSingleUser(mLiveStreamObject.getAuthor(), new FollowModel.QueryFollowListener() {
@Override
public void onQueryFollowSuccess(boolean isFollowing) {
if (isFollowing){
followingImg.setVisibility(View.VISIBLE);
isFollowingUser = true;
} else {
followingImg.setVisibility(View.GONE);
isFollowingUser = false;
@Override
public void onQueryFollowError(ParseException error) {
public static void getAvatars(User user, ImageView imageView){
ColorDrawable colorDrawable = new ColorDrawable(ContextCompat.getColor(Application.getInstance().getApplicationContext(), R.color.highlight_light_ripple));
// Load profile Photos
if (user.getProfilePhotos() != null && user.getProfilePhotos().size() > 0) {
Glide.with(Application.getInstance().getApplicationContext())
.load(user.getProfilePhotos().get(user.getAvatarPhotoPosition()).getUrl())
.error(colorDrawable)
.centerCrop()
.circleCrop()
.fitCenter()
.placeholder(colorDrawable)
.into(imageView);
} else {
.load(colorDrawable)
.into(imageView);
<?xml version="1.0" encoding="utf-8"?>
<merge xmlns:android="http://schemas.android.com/apk/res/android"
xmlns:aapt="http://schemas.android.com/aapt"
xmlns:app="http://schemas.android.com/apk/res-auto"
xmlns:tools="http://schemas.android.com/tools"
android:layout_height="wrap_content">
<View
android:id="@+id/imageCenterView"
android:layout_width="1dp"
android:layout_height="1dp"
app:layout_constraintBottom_toBottomOf="@+id/livestreamingHeader_streamerImage"
app:layout_constraintEnd_toEndOf="@+id/livestreamingHeader_streamerImage"
app:layout_constraintStart_toStartOf="@+id/livestreamingHeader_streamerImage"
app:layout_constraintTop_toTopOf="@+id/livestreamingHeader_streamerImage" />
<com.sos.GD_Live.modules.circularimageview.CircleImageView
android:id="@+id/livestreamingHeader_streamerImage"
android:layout_width="@dimen/icon_xlg"
android:layout_height="@dimen/icon_xlg"
android:layout_marginStart="@dimen/spacing_md"
android:layout_marginTop="@dimen/spacing_md"
android:layout_marginBottom="@dimen/spacing_md"
app:layout_constraintBottom_toBottomOf="parent"
app:layout_constraintStart_toStartOf="parent"
app:layout_constraintTop_toTopOf="parent"
android:layout_marginLeft="@dimen/spacing_md" />
<TextView
android:id="@+id/livestreamingHeader_status"
style="?attr/textStyleP3Inverse"
android:layout_width="wrap_content"
android:minWidth="26dp"
android:padding="1dp"
android:text="00:00"
android:background="@drawable/bg_livestreaming_rounded_rect_red_carrot"
app:layout_constraintEnd_toEndOf="@+id/imageCenterView"
app:layout_constraintStart_toStartOf="@+id/imageCenterView"
app:layout_constraintTop_toBottomOf="@+id/livestreamingHeader_streamerImage" />
<LinearLayout
android:id="@+id/livestreamingHeader_streamerInfo"
android:layout_marginStart="@dimen/spacing_sm"
android:layout_marginEnd="@dimen/spacing_md"
android:gravity="center_vertical"
android:orientation="horizontal"
app:layout_constraintBottom_toTopOf="@+id/livestreamingHeader_subtitle"
app:layout_constraintStart_toEndOf="@+id/livestreamingHeader_streamerImage"
app:layout_constraintVertical_chainStyle="packed"
android:layout_marginRight="@dimen/spacing_md"
android:layout_marginLeft="@dimen/spacing_sm">
<TextView
android:id="@+id/livestreamingHeader_name"
style="?attr/textStyleP2Inverse"
android:ellipsize="end"
android:maxWidth="@dimen/streamer_name_max_width"
android:maxLines="1"
tools:text="Maravilho, "
android:singleLine="true" />
<TextView
android:id="@+id/livestreamingHeader_age"
tools:text="25"
android:maxLines="1" />
<ImageView
android:id="@+id/livestreamingHeader_followedStreamer"
android:layout_marginStart="4dp"
android:visibility="gone"
app:srcCompat="@drawable/ic_livestream_favorites_streamer"
android:layout_marginLeft="4dp" />
</LinearLayout>
<TextView
android:id="@+id/livestreamingHeader_subtitle"
android:layout_width="0dp"
android:alpha="0.5"
android:maxWidth="120dp"
app:layout_constraintEnd_toEndOf="parent"
app:layout_constraintStart_toStartOf="@+id/livestreamingHeader_streamerInfo"
app:layout_constraintTop_toBottomOf="@+id/livestreamingHeader_streamerInfo"
android:layout_marginRight="@dimen/spacing_md" />
</merge>
This is the image if it didnt upload properly.
can you post some screenshots of your app in action?Check out this cool app
Saver for Whatsapp, Instagram, Facebook, Twitter and Likee with cool features, dark mode and no annoying fullscreen ads!
Leave a 5 stars review if u like the app!
https://play.google.com/store/apps/details?id=com.status.ssdownloader
Tube517, Thank you for the suggestion. Updating Android System WebView worked. It seems that I was unlucky enough to get signed out while WebView was broken, so apps which required me to be signed in didn't work, and I couldn't sign in because signing in requires WebView.
