Old phone won't charge
For future reference, when ordering cellphone batteries--
It is best to just open your browser, enter the entire model number of the battery {and nothing else}, and then hit 'enter'.
Ignore any information about whatever particular phone that it is supposed to fit that may come up.
The model number of the battery is what is important-- as long as that matches you are golden.
Help Hudl2 rom
Hi I got a hudl 2 which still sadly runs kitkat and was never updated to lollipop, it also is full of bloatware, I have heard/read that marshmallow is the best android operating software for a hudl2, but the links for the room are no longer available. Does anybody know where I can get them or other customer ROMs?Has anybody upgraded their huddle2, what did you use?
Any tips, links, or info appreciated.
you usually can get anything root related like custom roms over at https://forum.xda-developers.com/ but looks like there were not much of a community for the device. plus all the posts their are way dated and i doubt any of the links to the roms will still work. most of the developers will only support those files for so long. they do cost money to use those file sharing websites. you are better off just getting a new device.
Wireless charging question
I looked up your other post and it appears you have a Pixel 3A, which does NOT support wireless charging. The Pixel 3 does but the 3A does not.
So, if you purchased a wireless charging pad just for this phone I'd say return it as it won't do you any good. The reason it gets hot is the metal in the phone (does it have a metal back?) is putting a load on the charger and it's the charger that is getting hot in turn transferring that heat to the phone. This isn't doing either of them any good and may actually damage the charger.
Your 3A does support wired fast charging with the proper charger and cable.
Filter
