How to download PDF in webview
Yeah.
Well, developing an app is one thing.
Getting one to work is a other.
Getting one that works and is secure enought to use for your work is yet another still.
The browsers I put links to above are all FOSS, Free Open Source Software- so that means that you can feel free to decompile, inspect, and see why your app differs in respect to downloading.
Anyway, try setting one of them up as I mentioned, an see what happens.
I suggest starting out with Lightning.
Reminder app that keeps alerting every 5 minutes or so until confirmed?
I've used rtm, todoist, and many others. Problem is it alerts once and, if I don't notice it, I don't get the reminder. It is in my notifications, but I don't look at my notifications. (you need to pull down... But out of sight out of mind.). Is there a reminder app that when I set a reminder, it will remind me every few minutes until I acknowledge the alert?
Forget it, I found an app that does pretty much what I'm looking for. It's called alarm and pill reminder. It continuously makes noise until you snooze or dismiss.
Maximum power saving mode
Hi all,
I wish to count my steps and specifically use the PACER app in maximum power saving mode.
I have set the special access to allow use in data saver and this has not rectified it and allowed all permissions, but when I turn the power saver on it does not count steps any ideas how to sort this?
Tia
I've not really used this mode myself, but I suspect power saver mode shuts down the sensors in your phone, to save battery consumption. And this includes the accelerometer, which is used to count your steps based on movement. Immediate solution is not to use power saver while you're working out with this Pacer app, or other pedometer and health tracker apps.
Data saver is only really for reducing the amount of wireless data your phone uses, like for if you have a limited allowance from your carrier. But that shouldn't affect health tracker apps though.
Google page
Nova is ok.
Personally, I like sleek and simple.
KISS (yes, it stands for what you think) is my favorite for quite some time.
At first, I did not think I was going to like it- but after about an hour I knew that it was what I wanted.
Nothing is faster, or makes your device easier to work with.
It actually learns your habits and becomes faster as you use it.
https://f-droid.org/en/packages/fr.neamar.kiss/
Thanks. I'll take a look.
Help Decrypt SD Card Data on Same Device After Hard Reset
Nah. It doesn't offer any option to decrypt.
It says:
'This SD Card cannot be decrypted because it was encrypted on another device. .....'
Okay, so I read both the links you shared.
The former one sounds logical tho its old and you're probably right about the advanced encryption techniques which is why i'll make a copy of the sd card first.
Not trying the latter one because it needs root.
I will follow the sequence and then let's see. I'll update you. Thanks
Filter
