No more vibration feedback, no more fingerprint animation at all, just a lock but that is about it.what does this mean? no more animation? or no more fingerprint reader?
i only see one post that mentions it was slow. i see only a small handful that mentions other complaints. it is not like it is a consistent complaint(s) either......plus like i said 4.6 out of 5 stars is really good. i really do not pay close attention to these reviews. i mainly read or watch reviews on youtube or places like cnet and then try and play with it before i buy it.What am I talking about?
https://www.amazon.com/Samsung-Elec...show_all_btm?ie=UTF8&reviewerType=all_reviews
I'm afraid this wouldn't help anyway. It would allow your phone to read files on the external drive, so if you wanted to play musics from it then great. It would also allow you to copy files there. But you won't be able to run apps from there (either via WiFi or OTG).
How much pixel density do you need? What resolution do you run these games at? The 390ppi density of those 2 phones is not high by current standards, but on the other hand I'm sure that you don't need the 570 ppi density of the S9. Quite often the correct question to ask is "what's enough?" rather than "which is higher?" - though as your phone usage is very different from mine, and your eyes probably are too, I can't answer that for you.
But I'm surprised you say that the S9 ever wins in CPU: both of those phones use Snapdragon 865+, which will handily beat the s845 of the better variant of the s9 (we'll not even talk about the Exynos variant, which lags behind the s845). I can't myself see any contest in the processors, especially if your main use is graphically-intensive games.
But assuming that your reason for considering these options is partly budgetary, have you considered the s10 or s20 series? You may be able to find models there that give you the higher density screen plus greater storage without the price premium of the s21.
so sadI have a zotac zbox id18
cpu:celeron 1007u dual core 1.5 GHz
ram:ddr3 8 gb (4 gb x 2)
storage: 500gb hdd (soon to be 1 terabyte hdd or ill get a ssd if I can afford one : P)
keyboard: razer chroma ornata
mouse: steelseries rival 3
displays: a generic tv (Insignia NS-24E340A13) and generic monitor (NEC AS221WM)
you can't....unfortunately.....it happens with all updates, things that you are used to maybe have changed or done away with. with android 11 on my note 10+, the volume slider is on the left of the screen with the ability to access the ability to change volumes on ringtone, media, notifications, system and Bixby via the 3 dots.Used to have a volume slider that appeared on the side of the screen and you could change the volume level of individual apps and access more volume settings. Now i get a volume slider that appears at the top of the screen and just has a simple slider for media. How do I get my old slider back?
Line 1
Line 2
Line 3
Maintains white space
Doesn't turn :) into emoji
etc...
