Recieving low res MMS
Hello mikedt... Thank you for your reply.
It's a crazy thing. I can send a photo to anyone, even myself, and it arrives unaltered. They send the same image back to me and it goes from say 300mb to 180kb. Doesn't seem to matter who their carrier is. Happens between my phone and any of the others on our Verizon plan. They don't have this problem, only me. However, mine is the only one thats rooted. It's extremely frustrating when friends send me an image with text and it's completely unreadable.
I was hoping that it's a setting buried somewhere that I'm missing. Any thoughts?
Android equivalent of an iPod Touch (or iPad Mini)
Quite frankly I don't think there really is much in way of Android media players, that are not phones, like the iPod Touch is to the iPhone. There's things like Sony NW-A55, which is described as an Android Walkman, and I think Archos may do one as well.
The Sony has no mention of Miracast though.
https://www.sony.com/electronics/support/digital-music-players-nw-nwz-a-series/nw-a55/specifications
Although I believe Miracast is now been deprecated, and is no longer a feature in new devices.
You may have to use an older smart-phone(without a SIM) to do what you require?
Help multiOs app with android studio
Hello everyone,
can i convert a web page into an app for both ios and android with android studio,
managed to get this done for android device , but do not know how to start with the ios app conversion,
all and any help would be useful
Thanks
Basically you can't. Making or converting iOS apps requires Xcode on an Apple Mac, and that's it. I'm not a dev, but I don't think that Android Studio and Xcode even speak the same languages. Android Studio it's Java or Kotlin, and Xcode I think it's Objective C you have to use.
Annoying "system notifications"
It's surprisingly hard to be unambiguous when typing short messages, because your context is not the same as the reader's. Even now I'm not quite sure what "even by app" means: within the app whose notification you wish to change or using a different app? And assuming the latter is that using this other app as a sound picker (when you select to change the notification you can choose which app you use - provided you don't set one of them as the default) or in some other way?
Anyway, have you put your notification tones in a folder called "Notifications" in your internal storage? That's been the standard place to put them for at least the last decade, and still works in Android 11. If that isn't working on your phone then that's something that Samsung have done, it's not Android. In that case maybe see if you can work out what app is being used as the sound picker (the thing that allows you to choose a sound clip when you try to set a notification tone), locate it in Settings (I believe Samsung rename the submenu as "App Manager" rather than just "Applications" or "Apps & Notifications") and clear any defaults for it - if you can do that it ought to ask you which app you want to use, and then you can see whether something else (a file browser, Zedge, whatever) can do a better job.
Good luck.
Help SD card Encryption inadequate
Why is my laptop's SSD encrypted? After all, anyone who can enter my password can read the contents of the drive.
What you are asking is exactly equivalent to that question above. But since you can access the card when it's in the phone, is it surprising that anyone else who can unlock the phone can access it?
The point of encrypting is that nobody can remove the card and read it using a different device. Whereas if the card isn't encrypted someone who can't unlock your phone can just pop the card out and read it (and it's the same with the laptop: it's to protect the contents against someone who doesn't know my password accessing the drive through other ways).
how to change android account?
background: I'm getting emails saying i successfully bought some items (in Thailand) .. I have not paid for anything.. yet. If someone is using my email then i guess they don't see any replies.. or this is worse than i expect and they have access to my account. .
I have had this address for a very long time. I have changed my gmail account pwd to something more cryptic but would like to discard that gmail address and use another one that most friends and companys know me by.
My android devices and anything new i buy are all signed in with the original gmail account.
Can you delete a gmail address (rather than just not use it) How do i go about it and what should i expect in doing this.. 'if' it is possible?
appreciate you help.. sad times we're living in.
you can check your google account Security and go to my devices and sign out of devices that you dont own but i dont know if this will help
Filter
