Hdmi adapter with Ethernet port
Hello all,
I am trying to do some streaming online from my android VIVO IQOO neo 3.
I bought a Video Capture Card and a USB c hub with hdmi output but it did not work. I tried with another one and I get the same thing!
On Amazon sellers are claiming that the Hub is working with android phones but I did not get noting on mine.
I did some research and have seen people using a simple adapter with jus one HDMI output and it worked for them. But the issue here that I wanna try playing games with Ethernet and I really need and adapter with both of them (HDMI + Ethernet). I noticed also that even if these Hubs cost money they don't deliver a fast recharge to the phone and it keeps draining battery while connected to them.
Have you guys any idea of how I can connect my phone to the Capture Card with HDMI without using any app (as apps use CPU with results in game lag) and have Ethernet in the same time while my phone is charging well?
I also thought to connect a splitter with 3 type C female and put:
- recharge caple
- hdmi simple adapter
- Ethernet simple adapter
But I really don't have a clue if this will work or broke my phone :)
Thank you in advance!
I'm over it - not receiving text messages
Hi Sarah, I combined the three threads you started into one. :)
Does your old phone still have mobile data, or is it on WiFi?
The messages are SMS, and not some other protocol (WhatsApp/Signal/whatever other app)?
Good question, what app on your old phone is getting the messages?
Can you send texts on your new phone? I'm asking about regular texts using the included Google Messages, not WhatsApp or similar app.
App notification.
If this notification is on your phone, simply pulling the notification bar down should enlighten you.
If this is a screen shot from another phone, you are most likely out of luck for information here.
There are countless icons and unless someone here is familiar with the one in question, and that is quite unlikely, we can't help you. Asking the source of a screenshot is your best avenue. Good luck.
Does AndroidX BiometricPrompt APIs identify new faces registered in device?
I am using AndroidX BiometricPrompt APIs to authenticate user to use my app using their registered fingerprint or face id.
As fingerprint authentication can be used with crypto object and secret key is stored for this fingerprint in keystore. And when new fingerprint registered the key gets invalidated and user will be prompted to register for biometric login again when he tries to login into the app.
Similar functionality I need to implement for Face ID authentication into app, but did not find anything related to identification of new face id registration in android device / API.
Request your inputs to implement new Face ID registration which will invalidate user login using Face ID and ask him to register again.
Thanks in advance.
Jorte notification sound
Hi,
I had the same problem and found the solution :
The sound of the notifications of the calendar was done by another application and not by Jorte. This other application is the default calendar which was installed in Android (named "Agenda"). In this application, I set the sound I wanted and it worked out !
I hope it will work for you too.
Filter
