@Override
setContentView(R.layout.activity_main);
BottomNavigationView bottomNavigationView = (BottomNavigationView) findViewById(R.id.bottom_navigation);
rec = findViewById(R.id.btn_rec);
chronometer = findViewById(R.id.chronometer);
prgwait = findViewById(R.id.wait);
stop = findViewById(R.id.btn_stop);
ActivityCompat.requestPermissions(MainActivity.this, new String[]{Manifest.permission.RECORD_AUDIO, Manifest.permission.WRITE_EXTERNAL_STORAGE}, REQUEST_RECORD_AUDIO_PERMISSION);
rec.setOnClickListener(new View.OnClickListener() {
@Override
public void onClick(View view) {
prgwait.setVisibility(View.VISIBLE); //start progress
chronometer.setVisibility(View.VISIBLE);
rec.setVisibility(View.GONE);
prgwait.setVisibility(View.GONE); //stop progress
stop.setVisibility(View.VISIBLE);
chronometer.setBase(SystemClock.elapsedRealtime());
chronometer.start();
Toast.makeText(MainActivity.this, "Registration started", Toast.LENGTH_SHORT).show();
//start rec
recorder = new MediaRecorder();
recorder.setAudioSource(MediaRecorder.AudioSource.MIC);
recorder.setOutputFormat(output_formats[currentFormat]);
//recorder.setOutputFormat(MediaRecorder.OutputFormat.THREE_GPP);
recorder.setAudioEncoder(MediaRecorder.AudioEncoder.AMR_NB);
recorder.setOutputFile(getFilename());
recorder.setOnErrorListener(errorListener);
recorder.setOnInfoListener(infoListener);
try {
recorder.prepare();
recorder.start();
} catch (IllegalStateException e) {
Log.e("REDORDING :: ", e.getMessage());
e.printStackTrace();
} catch (IOException e) {
audioManager = (AudioManager) getApplicationContext().getSystemService(Context.AUDIO_SERVICE); //record the audio of device
audioManager.setMode(AudioManager.MODE_IN_CALL);
audioManager.setSpeakerphoneOn(true); //enable the speaker for record the voices of the call
//end code for rec calls
//stop a rec
stop.setOnClickListener(new View.OnClickListener() {
@Override
prgwait.setVisibility(View.VISIBLE); //start progressbar
stop.setVisibility(View.GONE);
chronometer.stop();
chronometer.setVisibility(View.GONE);
rec.setVisibility(View.VISIBLE);
audioManager.setSpeakerphoneOn(false); //turn off the speaker
try {
if (null != recorder) {
recorder.stop();
recorder.reset();
recorder.release();
recorder = null;
} catch (RuntimeException stopException) {
Toast.makeText(MainActivity.this, "Record saved", Toast.LENGTH_SHORT).show();
//end stop code
private String getFilename() {
String filepath = Environment.getExternalStorageDirectory().getPath();
File file = new File(filepath, AUDIO_RECORDER_FOLDER);
if (!file.exists()) {
file.mkdirs();
return (file.getAbsolutePath() + "/" + System.currentTimeMillis() + file_exts[currentFormat]);
private MediaRecorder.OnErrorListener errorListener = new MediaRecorder.OnErrorListener() {
@Override
public void onError(MediaRecorder mr, int what, int extra) {
"Error: " + what + ", " + extra, Toast.LENGTH_SHORT).show();
private MediaRecorder.OnInfoListener infoListener = new MediaRecorder.OnInfoListener() {
@Override
public void onInfo(MediaRecorder mr, int what, int extra) {
"Warning: " + what + ", " + extra, Toast.LENGTH_SHORT)
.show();
