[INFO][GENERAL]What causes hard-bricks and can you recover from them? (Device-neutral)
- By AlinTecsan
- Rooting
- 4 Replies
Another reasons for hard brick may be :
Incorrect partition SD card such as 4025 MB which i recommend do not attempt to modify the internal memory OR Extend or other bad sensitive modify
Install another model of samsung to an device samsung or even unsupportable rom or android upgrades small android device with higher such as nougat etc.
Incorrect use of root or even deleting important system files
Install bad Custom Rom etc.
Incorrect repartition with odin already
Swap mb kb or even worse
That's i see in some videos mine happened one of the symptoms described.
I will attempt to remember that.
