Earbuds Pause/Next/Previous is buggy
I have tried clearing data but this did not remedy the odd behavior.
I also uninstalled the app and reinstalled it, but that did not remedy either.
In addition, I uninstalled the app and installed ANOTHER MP3 player, but the odd behavior still remains, leading me to believe it has nothing to do with the app, but rather it's something to do with a system setting that somehow, without my knowledge or awareness got changed.
Anyone have any ideas?
TIA
Ken
[INFO][GENERAL]What causes hard-bricks and can you recover from them? (Device-neutral)
Another reasons for hard brick may be :
Incorrect partition SD card such as 4025 MB which i recommend do not attempt to modify the internal memory OR Extend or other bad sensitive modify
Install another model of samsung to an device samsung or even unsupportable rom or android upgrades small android device with higher such as nougat etc.
Incorrect use of root or even deleting important system files
Install bad Custom Rom etc.
Incorrect repartition with odin already
Swap mb kb or even worse
That's i see in some videos mine happened one of the symptoms described.
bluetooth connection with G8/G8X
I have a LG G8 and a LG G8X both running android 10. I can pair my bluetooth headset with each. However, when I turn on my bluetooth headset, it will only connect with one of my devices. I have tried this with four different bluetooth headsets to no avail. Any suggestions would be helpful.
Many BT headphones and speakers will only connect to one device at a time. However I know that Bose QC2 and Sony WH-1000XM3 headphones can connect to two devices at a time.
How to resize active screen area / change height of screen?
I can't imagine you can do this without root: it's changing the way the display system works, so if Samsung haven't provided the option you'll surely need to be able to grant something system privileges in order to make that change, and that's what root does.
Thanks for your reply
If you know of a way to do this with root, is there any chance the permissions can be granted with ADB commands, as I know this works for some apps that require root.
Tablet not responding
I can now confirm that following the proceedure in the video above fixed the issue I had with the unresponsive Samsung Galaxy Tab A (2016) T580 (10.1 inch).
I disconnected the battery ribbon cable, disconnected the screen ribbon cable, reconnected the screen ribbon cable then reconnected the battery ribbon cable. My original idea of simply disconnectingthe battery and reconnecting it to "break a software loop" did now work. I have no idea why it is necessary to do both cables. Something to do with how the screen ribbon cable is seated, perhaps. Perhaps somebody with more tech know how than me can explain what is going on. All I know is my tablet is now talking to me agaon.
NICE!!!!!!!!!!!!!
thanx for posting your solution......you are braver then i am. i would have never attempted to open things up like that.
Help Installing USB Ethernet Adapter drivers
<ul style='margin-top:0; margin-bottom:0;'>
<li dir='ltr'>Prepare to build the driver, you need the Linux kernel sources installed on the</li>
</ul>
<li dir='ltr'>build machine, and make sure that the version of the running kernel must match</li>
</ul>
<li dir='ltr'>the installed kernel sources</li>
</ul>
Filter
