No internet on wifi or data
How exactly would I install this with no way to transfer data to or from phone?
Possible workaround. Seems bluetooth still works
installing to your new phone and sending the app to your old phone vis Bluetooth.
Well according to your on words "
Possible workaround. Seems bluetooth still works." and Bluetooth is a method of transferring data. You ask how, install the app I recommend on your new phone and use it to transfer the same app "Bluethooth Sender" to your old phone. The use bluethooth sender from your old phone to transfer data to your new phone.
Thats how you transfer data by means of bluethooth.
You could try booting into safe mode and check your wifi.
Help Where is CoordinatorLayout in Android Studio 4.0?
I am new here, so I hope I am doing this right. I am using Android Studio 4.0. The tutorial I'm following calls for dragging and dropping a CoordinatorLayout from the palette onto the screen in design view. The problem is that I don't have a CoordinatorLayout in my palette. I have looked under every section of the palette and there is no CoordinatorLayout. Was it removed from Android Studio altogether or what? What gives?
Help Archos 101 G9 android problem
Hello people on the internet, have you solved the problem yet? Because I'm in a same situation, where my Archos 101 G9 Turbo tablet constantly boots into Archos A101S Recovery Menu by holding down the up volume with the power button, therefore I got into the "Recovery Mode" and pressed this Format System>Reformat Device... But i just wanted to Format the device so its able to be used like new, but I didn't know that you would need to connect the computer, therefore as I always try to turn the system on, it constantly boots into Archos A101S Recovery Menu although I'm not holding any volume keys. PLEASE READ THIS AND REPLY ASAP YOU KNOW HOW TO FIX THIS PROBLEM...
regarding
Maksim Belodedov
I am new here, so I hope I am doing this right. I am using Android Studio 4.0. The tutorial I'm following calls for dragging and dropping a CoordinatorLayout from the palette onto the screen in design view. The problem is that I don't have a CoordinatorLayout in my palette. I have looked under every section of the palette and there is no CoordinatorLayout. Was it removed from Android Studio altogether or what? What gives? SOMEBODY PLEASE HELP ME!!!
Huawei P30 Lite
welcome to af!!!!!!!!!!!!!!
this is an english only site.use google translate to translate your post. just type in what you want to say in your language and google will translate it for you. you can then copy and paste your reply here.
google translated:
I wanted to recover photos permanently deleted from the phone. How do I do it, can someone explain it to me?
if you had used google photos, you would not have this issue. it automatically saves your photos to the cloud. i never have to worry about my photos. everytinme i upgrade my phone, i just sign in and there are my photos from my old phone.
as far as your deleted photos, were these stored on your sd card or internally on your phone?
Pineboook Pro and Android
I recently grabbed a pinebook pro and really like it. The community seems to be struggling with Android images ,however, (https://forum.pine64.org/showthread.php?tid=9205) and I thought I would do a small crosspost move here to see if anyone around here needed a project and wanted to help these guys with their Android woes.
Personally I haven't tried the android images yet, so I don't have a whole lot of input about it, just trying to draw a little attention to a good and worthwhile device that could use some love :D
How do I create multi-color input editor text?
As shown in the picture below, you want to create EditText, which allows users to enter text by color.
Currently, we make two EditText and TextViews that are inputted and printed.
EditText with textWatcher listener, so you can start with TextView.
Computes the currently selected color and character location to change and display the SpanableStringBuilder.
Here's the question:
1. How do I not print the text entered in EditText?
(EditText does not want to display on the screen after receiving input only.)
2. Is there a better way to create EditText for multiple colors?
toshiba thrive help
i have the rom links are dead :-(
ahhhh ok the issue now is that your device is so old that the links to the files no longer work. the developers usually support the device for so long. and the file sharing sites either come and go and some sites you have to pay to share the files. the only thing you can do is contacting the developer via a private message on xda. hopefully they will respond, and hopefully they still have the files.
Filter
